This LCD monitor from ASUS provides a crisper, broader, and brighter display, plus a host of features that enhance your viewing experience. With these features, you can enjoy the convenience and delightful visual experience that the monitor brings to you!
- ASUS VK228H - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class A
- Energy Consumption per Year
- 29.2 kWh
- Power Consumption (On mode)
- 20 W
- Stereo speakers, camera
- Panel Type
- TN
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 80000000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Black
- 51.4 cm x 20 cm x 38.55 cm
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, RoHS, WEEE, GOST-R, J-MOSS, EuP
- Display Type
- Energy Class
- Class A
- 29.2 kWh
- Diagonal Size
- 21.5"
- Viewable Size
- 21.5"
- Built-in Devices
- Panel Type
- TN
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Pixel Per Inch
- 102
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Vertical Refresh Rate
- 76 Hz
- Horizontal Refresh Rate
- 82 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- HDCP, anti-glare, Skin-Tone Selection, Trace Free Technology, ASUS Splendid Video Preset Mode, 72% NTSC colour gamut
- Black
- 51.4 cm x 20 cm x 38.55 cm - with stand
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 2 Watt
- VGA , DVI-D , HDMI , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable, tilt adjustment
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable , 1 x USB cable
- Power Supply
- Internal
- Voltage Required
- AC 120/230 V
- 20 W
- 25 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- Without stand - width: 51.41 cm - depth: 4.5 cm - height: 31.5 cm
- ENERGY STAR Certified
