ASUS VivoWatch features exclusive VivoPulse technology, which uses the built-in optical sensor to continuously, accurately, and safely monitor your heart rate without the need to wear an uncomfortable chest strap. ASUS VivoWatch uses these precise heart rate measurements to show you the number of calories you burn each day and provide helpful insights into your exercise and sleep quality.
Ensure you are getting the rest you need to feel your best every day. ASUS VivoWatch measures and analyzes your heart rate, sleep time, and how much you toss and turn to give you an insightful look into your sleep quality. ASUS VivoWatch also helps you wake up easily each morning with a gentle, vibrating alarm.
The Happiness Index(HI)is a simple numeric score based on your sleep and exercise measurements that provides a quick summary of the overall healthiness of your lifestyle.
Put your heart into better health
ASUS VivoWatch features exclusive VivoPulse technology, which uses the built-in optical sensor to continuously, accurately, and safely monitor your heart rate without the need to wear an uncomfortable chest strap. ASUS VivoWatch uses these precise heart rate measurements to show you the number of calories you burn each day and provide helpful insights into your exercise and sleep quality. -
Track your sleep
Ensure you are getting the rest you need to feel your best every day. ASUS VivoWatch measures and analyzes your heart rate, sleep time, and how much you toss and turn to give you an insightful look into your sleep quality. ASUS VivoWatch also helps you wake up easily each morning with a gentle, vibrating alarm. -
A healthier, happier you
The Happiness Index (HI) is a simple numeric score based on your sleep and exercise measurements that provides a quick summary of the overall healthiness of your lifestyle. -
Keep track of your family's well-being
Nothing is more important that the health and happiness of the people you care about. Using the ASUS HiVivo App or ASUS Healthcare website, you can easily stay up-to-date with the wellness of loved ones who wear ASUS VivoWatch, no matter where they live.
- ASUS VivoWatch activity tracker - black
- Product Type
- Activity tracker
- Tracking Data
- Calories burned, activity, sleep activity, heart rate, steps taken
- Connectivity
- Bluetooth
- Display
- Monochrome 128 x 128 pixels - Corning Gorilla Glass 3
- Input
- Touch screen
- Notifications
- Missed calls
- Charging terminals
- Supported Host Device OS
- iOS, Android
- Battery Run Time
- Up to 240 hours
- Black
- 50 g
- Product Type
- Activity tracker
- Android 4.3 (Jelly Bean) or later, iOS 8.1 or later
- Notifications
- Missed calls
- Tracking Data
- Black
- Sensors
- UV sensor, 3-axis accelerometer
Display
- Monochrome
- Resolution
- 128 x 128 pixels
- Protection
- Corning Gorilla Glass 3 (scratch resistant glass)
- Wireless Interface
- Bluetooth 4.0
Input Device
- Touch sensitive screen
- Run Time (Up To)
- 240 hours
- Recharge Time
- 2 hour(s)
- Details
- Wrist strap: 22 mm
- Vibrating Alert
- Protection
- Dustproof, waterproof
- IP67
- Included Accessories
- Charging cradle
