Asus VivoMini VM65N Intel Core i5-7200U 8GB 128GB 1TB  Win 10 Pro
Quicklinx: DMFWWS00 Mfr#: VM65N-G072Z
Processor Type: Core i5
Operating System: Windows 10 Home
Installed Memory: 8GB
Hard Drive Capacity: 1.128TB
Storage Type: SSD
  • Core i5
  • Bluetooth 4.0
  • IEEE 802.11n
£549.49 ex VAT
£659.38 inc VAT
ASUS VivoMini VM65N is a 2-liter mini PC that features the latest Intel'Skylake' processor architecture to deliver maximum performance while taking up as little space as possible. It is powered by a choice of 6th-generation Intel Core processors, and features discrete NVIDIA GeForce graphics for smooth 4K UHD visuals and casual gaming. In addition, SonicMaster audio and DDR4 RAM make it a wise choice for a daily computing platform or entertainment hub. Its compact design even houses Vivo DualBay to give you flexible storage options - you can choose between 2.5-inch SSDs or HDDs so you can speed up your operating system or have space for your movie and music libraries. It delivers superfast connectivity too, thanks to SuperSpeed USB 3.1 and 802.11ac Wi-Fi. VivoMini VM65N features a Zen-inspired spun-metal finish and an elegant Iron Gray color scheme. This stylish and well-crafted mini PC is a wonderful addition to any room of your home.
VivoMini VM65N comes with built-in SonicMaster speakers right out of the box so there's no need for external speakers. ASUS SonicMaster technology, tuned by the renowned ASUS Golden Ear team, gives you deep rich bass and crystal-clear vocals - all from a mini PC.
VivoMini VM65N features Vivo DualBay, a unique dual-storage design that can accommodate up to two 2.5-inch solid-state (SSD) or hard disk drives (HDD), or a single 3.5-inch HDD for added storage flexibility. So whether you're after larger storage capacities or faster data access speeds, you can mix and match between SSD or HDD options to better suit your needs. If you're looking for space to house your movie or music libraries, use a single 3.5-inch or two 2.5-inch HDDs. Alternatively, you can choose a combination of 2.5-inch HDD and SSD for faster data access to speed up your operating system.
  • Blazing performance, stunning visuals
  • Pitch-perfect audio
  • Easy-upgrade design
ASUS VivoMini VM65N - mini PC - Core i5 7200U 2.5 GHz - 8 GB - 1.128 TB
Personal computer - mini PC
1 x Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) (Dual-Core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 128 GB - SATA 6Gb/s - 2.5"
Hard Drive (2nd)
1 x 1 TB - SATA 6Gb/s
Optical Storage
No optical drive
Card Reader
4 in 1
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Controller
NVIDIA GeForce 930M / Intel HD Graphics 520
Audio Output
Stereo
GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0, 802.11ac
OS Provided
Windows 10 Home
Iron grey
19 cm x 19 cm x 5.62 cm
1.2 kg
Environmental Standards
ENERGY STAR Qualified
Personal computer
Product Form Factor
Mini PC
Iron grey
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
8 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
SO-DIMM 260-pin
Slots
2 (Total)
Unbuffered, dual channel memory architecture
Hard Drive
SSD - 2.5"
1 x 128 GB
Interface Type
SATA 6Gb/s
Hard Drive (2nd)
HDD
Interface Class
Serial ATA
1 x 1 TB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Card Reader
4 in 1 card reader
Supported Flash Memory Cards
MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
Sound Output Mode
Stereo
Speakers Included
2 x right / left channel
Wireless LAN Supported
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
Wi-Fi CERTIFIED
Bays
2 (total) / 0 (free) x internal 2.5" x 1/8H
Slots
1 (total) / 0 (free) x CPU , 2 SO-DIMM 260-pin
4 x USB 3.0 , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x headphones - mini-jack , 2 x USB 3.1 , 1 x TOSLINK output , 1 x microphone - mini-jack
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
UL, VCCI, BSMI, CCC, FCC
Power adapter
Power Provided
90 Watt
Operating System / Software
OS Provided
Windows 10 Home
ENERGY STAR Certified
19 cm
19 cm
5.62 cm
1.2 kg
Asus VivoMini VM65N Intel Core i5-7200U 8GB 128GB 1TB  Win 10 Pro Bundle deal on Asus VivoMini VM65N Intel Core i5-7200U 8GB 128GB 1TB Win 10 Pro
£729.35
saving £3.64
£648.66
Storage Type: SSD
Processor Model: I5-7200U
Type: Personal computer
Case Style: Desktop slimline
Optical Storage: None
Brand: Asus
Price Range Ex VAT: 500 - 750
