ASUS VivoBook 15 is the perfect combination of beauty and performance. Powered by modern hardware, it's the ideal laptop for daily computing and entertainment.
Amazing performance
The ASUS VivoBook 15 is powered by a fast processor, with plenty of RAM and gaming-grade graphics for smooth visuals and great gaming experiences. -
Complete connectivity
A USB 3.1 port with a reversible USB Type C connector makes connecting devices quick and easy. USB 3.1 provides fast data transfer speeds. You can transfer photos, music and large video files in a fraction of the time. -
ASUS Splendid technology
ASUS Splendid visual optimization technology provides better visuals for any type of content. It features several display modes, which can be accessed with a single click. -
Expansive audio
ASUS SonicMaster is a combination of hardware, software and audio tuning, designed with the goal of giving you a great audio experience. A professional-grade codec ensures precise audio encoding and decoding, while amplifiers, large speakers and resonance chambers perfectly suited for your specific device ensure a powerful audio delivery and deeper bass. -
Stays cool
Laptop cooling is important as it directly affects your computing experience. ASUS IceCool uses smart fan control, thin heat pipes and a clever internal layout to create an efficient cooling system.
- ASUS VivoBook 15 X542UA-GQ116R - 15.6" - Core i5 7200U - 4 GB RAM - 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
- Memory
- 4 GB DDR4
- Storage
- 1 TB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 620
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 2-cell
- Matte silver IMR (top), matte dark grey IMR (LCD cover)
- 38 cm x 25.1 cm x 2.32 cm
- 2.3 kg
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 1 TB HDD SATA / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- ASUS Splendid Video Intelligence Technology, anti-glare, 45% NTSC colour gamut, ASUS EyeCare Technology, Tru2Life
Audio & Video
- Graphics Processor
- Camera
- Yes - VGA
- Sound
- Stereo speakers, microphone
- Audio Features
- ASUS SonicMaster, ASUS AudioWizard
Input
- Keyboard, touchpad
- Numeric Keypad
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Technology
- 2-cell Lithium Ion
- Capacity
- 38 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 , VGA , USB 2.0 , HDMI , LAN , USB-C 3.1 Gen 1
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
- System password, ASUS IceCool design, ASUS Battery Health charging technology
- Theft/Intrusion Protection
- Included Accessories
- Power adapter
- 2.3 kg
