ASUS VivoBook S14 provides boundless productivity for people on the go. Its compact and lightweight design has a thin profile with a light weight. VivoBook S14 delivers uncompromising performance, it's powered by powerful processor. It also offers a crisp display in a frame size that's typical of smaller laptops.
For work or entertainment, anywhere
The compact and lightweight design of ASUS VivoBook S14 keeps you productive and entertained - anywhere. It's perfect for working remotely in a café, or watching movies during a flight. With a thin profile and a light overall weight, VivoBook S14 is a portable laptop. -
Crisp display
The display features an anti-glare coating and 178° wide-view technology to ensure that colors and contrast remain vivid and bold, even when viewed at sharp angles. It's perfect for viewing media or documents with friends and colleagues. -
Built for productivity
ASUS VivoBook S14 may be small, but it packs a punch. It's powered by high-performance processor with plenty of RAM. Its combination of SSD and HDD provides blisteringly-fast data access speeds and large storage capacity. And with ultra-fast dual-band 802.11ac Wi-Fi, you can enjoy high speeds! It's everything you need for versatility and performance. -
Comprehensive connectivity
When working on the go, connectivity is everything. ASUS VivoBook S14 features a USB 3.1 with reversible USB Type-C port for any-way-up connections and super-fast data transfers. Additional USB 3.1 and USB 2.0 ports, along with HDMI port and SD card slot, provide hassle-free compatibility with a wide range of peripherals, displays and projectors. -
Ergonomic backlit keyboard, plus touchpad
ASUS VivoBook S14 features a keyboard that provides a reassuringly solid feel for a comfortable typing experience. And backlighting helps you stay productive in any environment, day or night. VivoBook S14 also offers a touchpad engineered for maximum comfort and accuracy. Integrated palm rejection technology differentiates between fingertip and palm contact to counter unintentional cursor movement, helping improve accuracy. -
Enjoy worlds of color
ASUS Splendid visual optimization technology ensures great image quality for any type of content. It features four display modes, which can be accessed with a single click. -
Proprietary technology for clear, expansive audio
ASUS SonicMaster is a combination of hardware and software designed to provide amazing audio experiences. A unique codec ensures precise audio encoding and decoding, while amplifiers, large speakers and resonance chambers perfectly suited for your specific device ensure a powerful audio delivery and deeper bass. Additional signal processing and tuning help refine minute details, filter noise and improve audio clarity - so you get incredible, truly immersive sound.
- ASUS VivoBook S14 S410UA-BV050T - 14" - Intel Core i3 - 7100U - 4 GB RAM - 128 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i3 (7th Gen) - 7100U / 2.4 GHz
- Memory
- 4 GB DDR4 (provided memory is soldered)
- Storage
- 128 GB SSD
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 620
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 3-cell
- Security
- Firmware Trusted Platform Module (TPM) Security Chip
- Grey
- 32.64 cm x 22.55 cm x 1.875 cm
- 1.43 kg
- Specific Absorption Rate (SAR)
- 0.144 W/kg (body) , 0.144 W/kg (limb)
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i3 (7th Gen) 7100U / 2.4 GHz
- Number of Cores
- Dual-Core
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD M.2 SATA 6Gb/s
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Colour Gamut
- 45% NTSC
- ASUS Splendid Video Intelligence Technology, anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - VGA
- Sound
- Speaker, microphone
- Audio Features
- Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower
Input
- Keyboard, touchpad
Communications
- Wireless
- Technology
- 3-cell Lithium Ion
- Capacity
- 42 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB 3.1 Gen 1 , 2 x USB 2.0 , USB-C 3.1 Gen 1 , HDMI
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
- Grey
- Security
- System password, hard drive password
- Included Accessories
- Power adapter
- SAR Value
- 0.144 W/kg (body), 0.144 W/kg (limb)
- 1.43 kg
Sustainability Information
- TCO Certified
