Designed for everyday multitasking and entertainment for smart and practical users, the ASUS X series notebooks redefine your expectations of all-rounder notebook. With a spun-circle finish and patterned palm rests, the X series adds a touch of sophistication and elegance to everyday computing. It houses a large touchpad with intuitive multi-point smart gesture input, multiple USB 3.0 ports for fast data transfer and IceCool technology to keep your palm rests cool.
A classic, timeless design
Designed for everyday multitasking and entertainment for smart and practical users, the ASUS X series notebooks redefine your expectations of all-rounder notebook. With a spun-circle finish and patterned palm rests, the X series adds a touch of sophistication and elegance to everyday computing. It houses to a large touchpad with intuitive multi-point smart gesture input, multiple USB 3.0 ports for fast data transfer and IceCool technology to keep your palm rests cool. -
Providing a smooth computing experience
Value-packed with all the essentials, the X series reinvents your daily computing experience. Whether you are using it for work or for fun, this is an ideal machine for both productive computing and entertainment. It features a powerful processor and graphics card, and USB 3.0 for faster data transfer speed. ASUS X series gives you everything you need for a truly satisfying multitask computing and multimedia experience. -
Precise, crystal clear audio to complete the cinematic experience
Like other notebooks in the ASUS range, the X series comes equipped with SonicMaster technology and ASUS AudioWizard to bring you high fidelity audio. Experience omnidirectional sound and hear each individual instrument's nuances with the X series. -
Precise input
ASUS provides the extremely comfortable and responsive experiences in every application and at all times. The X series has a large touchpad equipped with Smart Gesture technology for quick and precise response across a wide range of touch inputs. The ergonomic seamless one-piece keyboard is designed to provide you the most comfortable typing experience.
- ASUS VivoBook X540LA-XX980T - 15.6" - Intel Core i3 - 5005U - 4 GB RAM - 1 TB HDD
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i3 (5th Gen) - 5005U / 2 GHz / 3 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 1 TB HDD / 5400 rpm
- Display
- 15.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 5500
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
- Battery
- 3-cell
- Silver gradient IMR with hairline
- 38.14 cm x 25.15 cm x 2.72 cm
- 1.9 kg
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i3 (5th Gen) 5005U / 2 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 1 TB HDD SATA / 5400 rpm
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Colour Gamut
- 45% NTSC
- Ultra Slim Design, ASUS Splendid Video Intelligence Technology, anti-glare
Audio & Video
- Graphics Processor
- Camera
- Yes - VGA
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower, ASUS AudioWizard
Input
- Keyboard, touchpad
- ASUS Smart Gesture technology
Communications
- Wireless
- Network Interface
- 10/100 Ethernet
- Technology
- 3-cell Lithium Ion
- Capacity
- 33 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V, 2.37 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB 3.0 , VGA , USB 2.0 , HDMI , LAN , USB-C Gen 1
- Memory Card Reader
- 3 in 1 (SD Card, SDHC Card, SDXC Card)
- System password, hard drive password, ASUS IceCool design
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- 1.9 kg
Sustainability Information
- TCO Certified
