Asus VivoBook S i3-5005U 4GB 1TB 15.6" Windows 10
Quicklinx: D973WS00 Mfr#: X540LA-XX980T
Display Size: 15.6in
Processor Model: I3-5005U
Operating System: Windows 10 Home 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 1TB
  • Core i3
  • Bluetooth 4.0
  • IEEE 802.11n
£281.94 ex VAT
£338.32 inc VAT
Designed for everyday multitasking and entertainment for smart and practical users, the ASUS X series notebooks redefine your expectations of all-rounder notebook. With a spun-circle finish and patterned palm rests, the X series adds a touch of sophistication and elegance to everyday computing. It houses a large touchpad with intuitive multi-point smart gesture input, multiple USB 3.0 ports for fast data transfer and IceCool technology to keep your palm rests cool.
  • A classic, timeless design
    Designed for everyday multitasking and entertainment for smart and practical users, the ASUS X series notebooks redefine your expectations of all-rounder notebook. With a spun-circle finish and patterned palm rests, the X series adds a touch of sophistication and elegance to everyday computing. It houses to a large touchpad with intuitive multi-point smart gesture input, multiple USB 3.0 ports for fast data transfer and IceCool technology to keep your palm rests cool.
  • Providing a smooth computing experience
    Value-packed with all the essentials, the X series reinvents your daily computing experience. Whether you are using it for work or for fun, this is an ideal machine for both productive computing and entertainment. It features a powerful processor and graphics card, and USB 3.0 for faster data transfer speed. ASUS X series gives you everything you need for a truly satisfying multitask computing and multimedia experience.
  • Precise, crystal clear audio to complete the cinematic experience
    Like other notebooks in the ASUS range, the X series comes equipped with SonicMaster technology and ASUS AudioWizard to bring you high fidelity audio. Experience omnidirectional sound and hear each individual instrument's nuances with the X series.
  • Precise input
    ASUS provides the extremely comfortable and responsive experiences in every application and at all times. The X series has a large touchpad equipped with Smart Gesture technology for quick and precise response across a wide range of touch inputs. The ergonomic seamless one-piece keyboard is designed to provide you the most comfortable typing experience.
ASUS VivoBook X540LA-XX980T - 15.6" - Core i3 5005U - 4 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i3 (5th Gen) 5005U / 2 GHz / 3 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
1 TB HDD / 5400 rpm
Optical Drive
No optical drive
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 5500
Integrated Webcam
802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
3-cell
Silver gradient IMR with hairline
38.14 cm x 25.15 cm x 2.72 cm
1.9 kg
Notebook
Operating System
Processor / Chipset
CPU
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz
Storage
Main Storage
1 TB HDD SATA / 5400 rpm
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Ultra Slim Design, ASUS Splendid Video Intelligence Technology, anti-glare, 45% NTSC colour gamut
Audio & Video
Graphics Processor
Camera
Yes - VGA
Sound
Stereo speakers, microphone
Audio Features
ASUS SonicMaster, ASUS Bang & Olufsen ICEpower, ASUS AudioWizard
Input
Keyboard, touchpad
ASUS Smart Gesture technology
Communications
Wireless
Network Interface
10/100 Ethernet
3-cell Lithium Ion
33 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
Headphone/microphone combo jack , USB 3.0 , VGA , USB 2.0 , HDMI , LAN , USB-C Gen 1
Memory Card Reader
3 in 1 (SD Card, SDHC Card, SDXC Card)
System password, hard drive password, ASUS IceCool design
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
1.9 kg
Software applications
Asus VivoBook S i3-5005U 4GB 1TB 15.6 Bundle deal on Asus VivoBook S i3-5005U 4GB 1TB 15.6" Windows 10
£464.45
saving £8.33
Optical Storage: None
Graphics: Intel HD Graphics 5500
Hard Drive Type: HDD
Brand: Asus
Price Range Ex VAT: 150 - 300
