Asus VivoBook Pro 15.6" Intel Core i7-8750H 8GB 1TB W10H
Quicklinx: F39CWS00 Mfr#: N580GD-DM230T
Display Size: 15.6in
Processor Model: I7-8750H
Operating System: Windows 10 Home 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 1TB
  • Core i7
£1,025.23 ex VAT
£1,230.27 inc VAT
The ASUS VivoBook Pro 15 is a slim and lightweight high-performance laptop that's powered by advanced processor. It features a crisp display with perfect color gamut, high-quality gaming-grade graphics, audio co-developed by Harman Kardon, and cooling and fast-charge technologies.
  • Aluminum design
    Each VivoBook Pro 15 is milled from high-strength aluminum that undergoes a series of intricate manufacturing processes to achieve its sleek and elegant final form.
  • Intelligent dual fans
    The VivoBook Pro 15 features a robust cooling system to ensure smooth and stable performance during high-load multitasking or gaming marathons. An intelligent dual-fan design has eight automatically-adjustable speeds to deliver maximum cooling efficiency with minimal noise. Its compact, hyper-cool, dual-copper thermal module leverages system heat pipes and fans to independently increase CPU and GPU performance.
  • Lifelike visuals
    The VivoBook Pro 15 combines optimized hardware and software to provide amazing visuals. A high-resolution panel with wide-view technology, perfect color gamut, and ASUS Splendid display technology provide richer, deeper and more accurate colors - for any type of content.
  • Immerse yourself in premium sound
    The VivoBook Pro 15 delivers amazing audio co-developed by Harman Kardon. Powerful speakers with Smart Amplifier technology help maximize volume while maintaining crystal-clear sound. Dual-coil, stereo speakers deliver loud, clear audio from a thin and lightweight device. ASUS Smart Amp technology provides the VivoBook Pro 15 with louder volume, more bass and more peak power, versus standard laptops. Carefully tuned speakers also provide a higher dynamic range for fully immersive sound that makes movies and games come alive.
  • Ergonomic backlit keyboard
    The VivoBook Pro 15 has a full-size backlit keyboard that's perfect for low-light settings. Its sturdy, single-piece keyboard with optimized key travel offers ergonomic and comfortable typing.
  • USB Type-C connectivity
    The VivoBook Pro 15 provides a USB 3.1 Gen 1 port with a USB Type-C connector that supports high data transfer speeds. The reversible USB Type-C connector design makes connecting any device effortless and quick.
ASUS VivoBook Pro 15 N580GD-DM230T - 15.6" - Core i7 8750H - 8 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Home 64-bit
Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
8 GB DDR4 (2 x 4 GB)
Storage
1 TB HDD / 5400 rpm + 16 GB SSD cache (M.2) (3D Xpoint (Optane))
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA GeForce GTX 1050
Video Memory
4 GB GDDR5 SDRAM
Keyboard Backlight
Integrated Webcam
802.11ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Security
Firmware Trusted Platform Module (TPM) Security Chip
Gold and metal with hairline finish
38 cm x 25.6 cm x 2.05 cm
1.99 kg
Environmental Standards
ENERGY STAR Qualified
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
6-core
Cache
9 MB
64-bit Computing
Chipset
Mobile Intel HM175
Intel Turbo Boost Technology 2.0
RAM
8 GB (2 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
1 TB HDD SATA / 5400 rpm
SSD Cache
16 GB 3D Xpoint (Optane) (M.2)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Ultra Slim Design, anti-glare, 45% NTSC colour gamut
Audio & Video
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Camera
Yes - HD
Sound
Harman/kardon stereo speakers, microphone
Audio Features
ASUS SonicMaster
Input
Keyboard, touchpad
Keyboard Backlight
Communications
Wireless
Network Interface
Gigabit Ethernet
3-cell lithium polymer
47 Wh
AC Adapter
Input
Output
120 Watt, 19 V, 6.3 A
Connections & Expansion
Headphone/microphone combo jack , HDMI , LAN , USB 3.1 Gen 1 , USB-C 3.1 Gen 1 , 2 x USB 2.0
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Case Material
Aluminum
Security
Fast charging
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
UL, BSMI, CB, CCC, FCC
1.99 kg
ENERGY STAR Certified
Software applications
Asus VivoBook Pro 15.6 Bundle deal on Asus VivoBook Pro 15.6" Intel Core i7-8750H 8GB 1TB W10H
£1,205.09
saving £3.64
£1,124.40
Optical Storage: None
Graphics: NVIDIA GeForce GTX 1050
Hard Drive Type: HDD
Touchscreen: No
Type: Laptop
Brand: Asus
Price Range Ex VAT: 1000 - 1500
