Everything you need, for all day computing.
Designed for all your needs, in a small and lightweight chassis. Despite its compact dimensions, the L402 is still loaded with all your 'must haves' for connectivity, giving you incredible productivity all day long, without you needing to compromise.
Durable, full-size chiclet keyboard
Just because the L402 is smaller in size, it doesn't mean you need to compromise your comfort. The full size chiclet keyboard features an improved design that allows for more accurate typing. It has 1.6mm of key travel with little key float for a solid feel and more comfortable typing experience. It's considerably durable too, with a 10-million keystroke lifespan.
Larger chamber speakers bring better videos and music to life
It's important that you can still listen to your music, watch and show off your videos even in this smaller device. ASUS L402 features high quality dual speakers with larger 9cc speaker chambers situated under the palm rest. These direct sound towards you for a truly immersive experience as your favourite movies and music come to life.
- ASUS VivoBook L402NA GA042TS - 14" - Intel Celeron - N3350 - 4 GB RAM - 32 GB eMMC
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Celeron N3350 / 1.1 GHz, up to 2.4 GHz / 2 MB Cache
- Memory
- 4 GB DDR3 (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 500
- Integrated Webcam
- Networking
- 802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet
- Battery
- 2-cell
- Dark blue IMR
- 33.9 cm x 23.5 cm x 2.19 cm
- 1.65 kg
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3 SDRAM
Storage
- Main Storage
- 32 GB eMMC
Display
- 14"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Ultra Slim Design, ASUS Splendid Video Intelligence Technology, glare
Audio & Video
- Graphics Processor
- Camera
- Yes - VGA
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: ASUS SonicMaster
Input
- Keyboard, touchpad
- ASUS Smart Gesture technology
Communications
- Wireless
- Network Interface
- 10/100 Ethernet
- Technology
- 2-cell Lithium Ion
- Capacity
- 32 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 33 Watt, 19 V, 1.75 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB 3.0 , USB-C 3.1 Gen 1 , USB 2.0 , HDMI , LAN
- Memory Card Reader
- Yes (SD Card)
- Dark blue IMR
- ASUS IceCool design, ASUS USB Charger+
- Included Accessories
- Power adapter
- 1.65 kg
Sustainability Information
- TCO Certified
