The ASUS VivoBook Flip 12 is designed to be thinner, lighter, more functional, and more intuitive than ever before. Each essential part of this 2-in-1 convertible laptop has been re-engineered to create a compact solution that offers ultimate flexibility.
Lightweight, ultimate portability
The ASUS VivoBook Flip 12 is light and has a small footprint, making it the perfect take-anywhere device that's always ready to go - wherever your day takes you. -
Engineered for ultimate flexibility and durability
The robust 360°, twin-gear metal hinge on this convertible laptop gives you the freedom to organize your life the way you want. Do your work in Laptop mode, then flip into Tent mode and share ideas with colleagues. Or create your own personal movie theater with Stand mode. With its lightweight design, the ASUS VivoBook Flip 12 is perfect for use in Tablet mode, too. -
Cinematic audiovisuals
ASUS Tru2Life Video technology makes any video look amazing. Through intelligent algorithms, it optimizes the sharpness and contrast of every pixel in every frame to produce incredibly vivid and realistic imagery - every time! ASUS Splendid display technology optimizes imagery to provide richer, deeper and more accurate colors - for any type of content. The ASUS VivoBook Flip 12 also delivers impressive audio, with dual speakers and ASUS SonicMaster technology for immersive surround-sound. -
Instant response to the light touch
The ASUS VivoBook Flip 12 features multi-touch screen technology designed to respond instantly to your every touch. High-precision sensors provide better sensitivity, making the screen of the ASUS VivoBook Flip 12 responsive to even the slight touch. -
All day battery
The ASUS VivoBook Flip 12 packs many hours of working time in one charge, so you can work on the go without constantly looking for power outlets. -
Faster, more stable Wi-Fi connections
The ASUS VivoBook Flip 12 features dual-band 802.11ac Wi-Fi for strong, stable signals and faster data transmission speeds. As an added advantage, 802.11ac Wi-Fi is less prone to interference from other wireless devices operating on the same bandwidth. -
Comprehensive connection
For maximum convenience and compatibility, the ASUS VivoBook Flip 12 also features USB 3.1 Type A Gen 1, standard USB port, and one HDMI port. And, it's easily expandable via the microSD card slot. -
Larger, ultra-precise touchpad
The ASUS VivoBook Flip 12 has a touchpad that's typically found on larger laptops. Designed for extra-sensitive responsiveness, the touchpad features Palm Rejection technology that's driven by an exclusive algorithm. This perfect balance between sensitivity and usability ensures effortless navigation with apps and other features.
- ASUS VivoBook Flip 12 TP202NA EH007T - 11.6" - Intel Celeron - N3350 - 2 GB RAM - 32 GB eMMC
- Product Type
- Notebook - flip design
- Operating System
- Windows 10 in S mode 64-bit
- Processor
- Intel Celeron N3350 / 1.1 GHz, up to 2.4 GHz / 2 MB Cache
- Memory
- 2 GB DDR3 (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics 500
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 2-cell
- Security
- Firmware Trusted Platform Module (TPM) Security Chip
- Black (LCD cover), star grey (top)
- 28 cm x 20 cm x 1.79 cm
- 1.27 kg
- Specific Absorption Rate (SAR)
- 0.323 W/kg (body) , 0.323 W/kg (limb)
- Product Type
- Operating System
- Windows 10 in S mode 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 2 GB (provided memory is soldered)
- Technology
- DDR3 SDRAM
Storage
- Main Storage
- 32 GB eMMC
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Colour Gamut
- 45% NTSC
- ASUS Splendid Video Intelligence Technology, glare, Tru2Life
Audio & Video
- Graphics Processor
- Camera
- Yes - VGA
- Sound
- Stereo speakers, array microphone
- Audio Features
- Output: ASUS SonicMaster
Input
- Keyboard, touchpad
Communications
- Wireless
- Technology
- 2-cell lithium polymer
- Capacity
- 36 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 24 Watt, 12 V
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB 2.0 , USB 3.1 Gen 1 , HDMI
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
- Security
- System password
- Included Accessories
- Power adapter
- SAR Value
- 0.323 W/kg (body), 0.323 W/kg (limb)
- 1.27 kg
Sustainability Information
- TCO Certified
