Asus VivoBook E406SA-BV133TS N3060 4GB 32GB Windows 10 - Blue
Quicklinx: DNNCWS00 Mfr#: E406SA-BV133TS
  • Celeron
  • IEEE 802.11n
Marketing description is not available.
  • Take-anywhere portability
    E406 is extremely portable at just 17.6mm thin and weighs just 1.3kg. It's an everyday laptop that keeps you productive and entertained - anywhere.
  • Smart performance
    The E406 features ultra-fast 802.11ac Wi-Fi for speeds up to 3x faster than 802.11n. From daily computing tasks to entertainment, this versatile laptop has everything you need.
  • NanoEdge display
    With a thin 7.8mm bezel and 76.5% screen-to-body ratio, the NanoEdge display on E406 provides you with more screen area for more immersive viewing.
  • Fanless design with low operational noise
    The fanless design of the E406 keeps noise levels down, ideal when you want to work silently in libraries or coffee shops. This approach also decreases power consumption, and improves system reliability by avoiding potential dirt-related component failures.
  • Enjoy worlds of color and pixel-perfect video
    ASUS-exclusive technologies ensure only the very best visual experience. ASUS Splendid visual optimization technology provides the very best visuals for any type of content. It features four display modes: Normal mode is ideal for daily tasks, Vivid mode optimizes contrast to deliver stunning photos and video; Eye Care mode reduces blue-light levels to ease eye strain and Manual mode allows for personalized color adjustments. ASUS Tru2Life Video technology intelligently optimizes each pixel in the video frame to increase sharpness and contrast by 150% so you'll enjoy the best possible image quality.
  • Stay cool - even after hours of use
    Laptop cooling is important because it directly affects your computing experience. ASUS IceCool technology uses thin heat pipes and clever internal layout design to create an efficient cooling system that keeps the average palm rest surface temperature below 36°C - lower than body temperature - so you get robust cooling performance and a comfortable user experience.
  • A safe fast-charging and longer-lasting battery
    You can work out of coffee shops or libraries for the entire day without having to look out for a power socket.
ASUS E406SA BV133TS - 14" - Intel Celeron - N3060 - 4 GB RAM - 32 GB eMMC
Notebook
Operating System
Windows 10 in S mode 64-bit
Intel Celeron N3060 / 1.6 GHz (2.48 GHz) / 2 MB Cache
4 GB DDR3 (provided memory is soldered)
Storage
32 GB eMMC
Display
14" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 400
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
3-cell
Iris blue IMR (LCD cover), iris blue painting (top)
32.64 cm x 22.65 cm x 1.76 cm
1.3 kg
Environmental Standards
ENERGY STAR Qualified
SAR
0.576 W/kg (body), 0.576 W/kg (limb)
Notebook
Operating System
Windows 10 in S mode 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
2.48 GHz
Number of Cores
Dual-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR3 SDRAM
Storage
Main Storage
32 GB eMMC
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Colour Gamut
45% NTSC
Anti-glare, ASUS EyeCare Technology, NanoEdge display
Audio & Video
Graphics Processor
Camera
Yes - VGA
Sound
Stereo speakers, microphone
Audio Features
Output: ASUS SonicMaster
Input
Keyboard, touchpad
Communications
Wireless
3-cell Lithium Ion
56 Wh
AC Adapter
Input
Output
33 Watt, 19 V, 1.75 A
Connections & Expansion
Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 , HDMI
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
ASUS IceCool design
Power adapter
UL, C-Tick, BSMI, CB, CCC, A-Tick, ErP 2013
SAR Value
1.3 kg
Sustainability Information
ENERGY STAR Certified
