Mobile performance, elegantly crafted - that's the Vivobook E200HA from Asus. Delivering superior performance when you're on the go, the Vivobook is designed to keep you productive all day long.
With numerous USB ports, a MicroSD card slot and a micro HDMI port, the Asus Vivobook has everything you need to stay connected when you need to be. Its generous battery life means you'll have plenty of time to get those everyday tasks done when you're out and about.
It's equipped with a powerful 1.84GHz Intel Atom processor, along with 2GB of RAM and a 32GB hard drive - so there's ample space for those essential documents. This practical notebook weighs less than 1kg, so its compact design means it's easy and convenient to carry around with you.
The Asus Vivobook E200 proves that performance and practicality don't have to come at the expense of affordability. For easy on-the-go computing, it could be the perfect solution.
Fully equipped, including USB 3.1 Type C
ASUS EeeBook employs a simple yet elegant design. Despite its compact dimensions, it has numerous USB ports, a micro HDMI port, and a MicroSD card slot so you have everything you need for everyday computing. -
Long battery life for all day computing
ASUS EeeBook gives you long times battery life so you needn't worry about running out of juice while you're working inflight or in a coffee shop, or when you're out and about. -
Fanless design
The fanless design of the ASUS EeeBook keeps noise levels down, ideal when you want to work silently libraries or leave it on overnight to download documents and files. -
Vivid colors with ASUS Splendid technology
Exclusive ASUS Splendid technology gives you vivid, accurate color by automatically fine-tuning various display settings to optimize all kinds of images. The result is richer, deeper colors and stunning visuals whether you're watching videos and movies, or browsing through your photos. -
ASUS SonicMaster technology
ASUS SonicMaster technology - tuned by the renowned ASUS Golden Ear team - uses a combination of precision engineering and software to deliver sound like you've never heard before from a laptop, with deep rich bass and crystal-clear vocals, even at the highest volume levels.
- ASUS VivoBook E200HA-FD0004TS - 11.6" - Intel Atom x5 - Z8300 - 2 GB RAM - 32 GB eMMC
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Atom x5 Z8300 / 1.44 GHz, up to 1.84 GHz / 2 MB Cache
- Memory
- 2 GB (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 11.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 2-cell
- Dark blue
- 28.6 cm x 19.3 cm x 1.75 cm
- 980 g
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 1.84 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
Storage
- Main Storage
- 32 GB eMMC
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Colour Gamut
- 45% NTSC
- Glare
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Yes - VGA
- Sound
- Speaker, microphone
Input
- Keyboard, touchpad
Communications
- Wireless
- Technology
- 2-cell Lithium Ion
- Capacity
- 38 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 33 Watt, 19 V, 1.75 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB 3.0 , Micro-HDMI , USB 2.0
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
- Dark blue
- Case Material
- Plastic
- Included Accessories
- Power adapter
- 980 g
Sustainability Information
- TCO Certified
