Asus Vivobook E200HA Z8300 32GB 11.6" Windows 10 64-bit
Quicklinx: C15RWS00 Mfr#: E200HA-FD0004TS
  • IEEE 802.11n
Mobile performance, elegantly crafted - that's the Vivobook E200HA from Asus. Delivering superior performance when you're on the go, the Vivobook is designed to keep you productive all day long.
With numerous USB ports, a MicroSD card slot and a micro HDMI port, the Asus Vivobook has everything you need to stay connected when you need to be. Its generous battery life means you'll have plenty of time to get those everyday tasks done when you're out and about.
It's equipped with a powerful 1.84GHz Intel Atom processor, along with 2GB of RAM and a 32GB hard drive - so there's ample space for those essential documents. This practical notebook weighs less than 1kg, so its compact design means it's easy and convenient to carry around with you.
The Asus Vivobook E200 proves that performance and practicality don't have to come at the expense of affordability. For easy on-the-go computing, it could be the perfect solution.
  • Fully equipped, including USB 3.1 Type C
    ASUS EeeBook employs a simple yet elegant design. Despite its compact dimensions, it has numerous USB ports, a micro HDMI port, and a MicroSD card slot so you have everything you need for everyday computing.
  • Long battery life for all day computing
    ASUS EeeBook gives you long times battery life so you needn't worry about running out of juice while you're working inflight or in a coffee shop, or when you're out and about.
  • Fanless design
    The fanless design of the ASUS EeeBook keeps noise levels down, ideal when you want to work silently libraries or leave it on overnight to download documents and files.
  • Vivid colors with ASUS Splendid technology
    Exclusive ASUS Splendid technology gives you vivid, accurate color by automatically fine-tuning various display settings to optimize all kinds of images. The result is richer, deeper colors and stunning visuals whether you're watching videos and movies, or browsing through your photos.
  • ASUS SonicMaster technology
    ASUS SonicMaster technology - tuned by the renowned ASUS Golden Ear team - uses a combination of precision engineering and software to deliver sound like you've never heard before from a laptop, with deep rich bass and crystal-clear vocals, even at the highest volume levels.
ASUS VivoBook E200HA-FD0004TS - 11.6" - Intel Atom x5 - Z8300 - 2 GB RAM - 32 GB eMMC
Notebook
Operating System
Win 10 Home 64-bit
Intel Atom x5 Z8300 / 1.44 GHz, up to 1.84 GHz / 2 MB Cache
2 GB (provided memory is soldered)
Storage
32 GB eMMC
Display
11.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
2-cell
Dark blue
28.6 cm x 19.3 cm x 1.75 cm
980 g
Notebook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
1.84 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
RAM
Storage
Main Storage
32 GB eMMC
Display
11.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Colour Gamut
45% NTSC
Glare
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Yes - VGA
Sound
Speaker, microphone
Input
Keyboard, touchpad
Communications
Wireless
2-cell Lithium Ion
38 Wh
AC Adapter
Input
Output
33 Watt, 19 V, 1.75 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , USB 3.0 , Micro-HDMI , USB 2.0
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Dark blue
Case Material
Plastic
Power adapter
980 g
Sustainability Information
TCO Certified
