Asus VivoBook Celeron N4200 4GB 1TB 15.6" Windows 10
Quicklinx: DRTQWS00 Mfr#: X540NA-GQ232T
Display Size: 15.6in
Processor Model: N4200
Operating System: Windows 10 Home 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 1TB
  • Pentium
  • Bluetooth 4.0
  • IEEE 802.11n
£248.60 ex VAT
£298.32 inc VAT
Designed for Productivity and Entertainment
The ASUS X540 Series is powered by the Intel® processors to give you smooth and responsive computing performance.
Elegant finished. Lightweight Design
ASUS X540 has a solid and lightweight chassis that weighs just 1.9kg – ideal to take with you when you’re out and about. Its premium brushed finish turns heads and makes sure that you stand out from the crowd.
Expansive Audio, Tuned by Experts
A mixture of hardware, software, and tuning, SonicMaster was developed with the clear goal of giving you the best notebook PC audio. A professional codec ensures precise sound performance; while an optimised amplifier, larger speakers and resonance chambers deliver powerful audio output and deeper bass. Additional signal processing helps fine tune the hardware, filtering noise and improving clarity so you can enjoy unrivalled audio on your X Series.
Crafted Speaker design for greater sound
The X540 features round speakers that maximise every cubic millimeter of available chassis space to give you better low frequency performance and reduced noise. The extra-large 19.4cc chamber provides superior bass and excellent sound clarity.
AudioWizard-Optimised Tuning
To customise audio settings to suit your own preferences, ASUS AudioWizard has five selectable modes. Music mode brings your favorite songs to life, while Movie mode provides a true cinematic experience. Recording mode gives dynamic and crystal-clear recordings, and Gaming mode adds a new dimension of enjoyment to your favorite games. Finally, Speech mode makes voices clear and powerful.
Enjoy a World of Colour with ASUS Splendid Technology
To ensure only the very best images, ASUS Splendid Technology has colour temperature correction to reproduce richer, deeper colours.
It features four visuals modes which can be accessed with a single click. Vivid Mode optimises contrast for browsing photos or watching videos and movies; Eye Care Mode reduces blue light levels and is ideal when you’re reading for long hours. Normal Mode has been tuned for daily tasks; while Manual Mode is for advanced colour adjustments.
Protect Your Eyes with ASUS Eye Care
Most LED panels emit blue light - the main cause of macular degeneration and retinal problems. ASUS Eye Care mode effectively reduces blue light levels by up to 33% to make reading comfortable, and to protect you from potential eye fatigue and other ailments.
Ergonomic Keyboard Design
Typing is now more comfortable than ever with the X Series’ full-size one-piece chiclet keyboard. An improved back-assembly provides 1.8mm of key travel and minimal key float, so you get a more solid typing feel.
Intuitive ASUS Smart Gesture input
ASUS Smart Gesture technology utilises an intelligent combination of hardware and software optimisation to give you precise input. Sophisticated smartphone touchscreen production methods result in a highly sensitive touchpad that allows you to pinch-zoom in and out, or scroll through images and webpages with ease.
Stays Cool,Even After Hours of Use
ASUS IceCool Technology gives X Series a unique internal design that addresses uncomfortable heating issues by preventing heat build-up under the palm rest. This keeps the palm rest surface between 28°C to 35°C – significantly lower than body temperature. This exclusive internal layout places heat producing components away from you, and when combined with exceptional cooling from the heat pipes and vents, ensures you stay comfortable even after long hours of use.
ASUS VivoBook 15 X540NA-GQ232T - 15.6" - Pentium N4200 - 4 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Home 64-bit
Intel Pentium N4200 / 1.1 GHz (2.5 GHz) / 2 MB Cache
4 GB LPDDR3
Storage
1 TB HDD / 5400 rpm
Optical Drive
No optical drive
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 500
Numeric Keypad
Integrated Webcam
802.11b/g/n, Bluetooth 4.0
3-cell
Security
Firmware Trusted Platform Module (TPM) Security Chip
Chocolate black IMR with hairline (LCD cover), gold IMR with hairline (top)
38.1 cm x 25.1 cm x 2.72 cm
2 kg
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.5 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
RAM
4 GB
LPDDR3 SDRAM
Storage
Main Storage
1 TB HDD SATA / 5400 rpm
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Ultra Slim Design, ASUS Splendid Video Intelligence Technology, anti-glare, 45% NTSC colour gamut
Audio & Video
Graphics Processor
Camera
Yes - VGA
Sound
Stereo speakers, microphone
Audio Features
ASUS SonicMaster, ASUS Bang & Olufsen ICEpower, ASUS AudioWizard
Input
Keyboard, touchpad
Numeric Keypad
Communications
Wireless
3-cell Lithium Ion
33 Wh
AC Adapter
Input
Output
33 Watt, 19 V, 1.75 A
Connections & Expansion
Headphone/microphone combo jack , USB 3.0 , 2 x USB 2.0 , HDMI
Memory Card Reader
Yes (microSD)
Software
Software Included
Dropbox (25 GB Cloud Storage)
Security
System password, hard drive password, ASUS IceCool design, ASUS USB Charger+
Power adapter
2 kg
Software applications
Asus VivoBook Celeron N4200 4GB 1TB 15.6 Bundle deal on Asus VivoBook Celeron N4200 4GB 1TB 15.6" Windows 10
£430.76
saving £8.33
£347.77
Optical Storage: None
Graphics: Intel HD Graphics 500
Hard Drive Type: HDD
Brand: Asus
Price Range Ex VAT: 150 - 300
