Asus VivoBook Celeron N4000 4GB 64GB EMMC 14" Windows 10S - Iris Blue
Quicklinx: F5VLWS00 Mfr#: E406MA-BV211TS
  • Celeron
  • IEEE 802.11n
The E406 is designed to help you be productive all day - even when you're on the move. This compact and lightweight laptop is powered by the advanced processor and provides a long-lasting battery life. And with a NanoEdge display for immersive viewing, it's excellent laptop for people on the go.
  • Smart performance
    The E406 is powered by a powerful processor that delivers amazing performance for both work and play. It has enough room for your files, music and movie libraries. It also features ultra-fast Wi-Fi connection. From daily computing tasks to entertainment, this versatile laptop has everything you need.
  • NanoEdge display
    With a thin bezel and high screen-to-body ratio, the NanoEdge display on E406 provides you with more screen area for more immersive viewing.
  • Fanless design with low operational noise
    The fanless design of the E406 keeps noise levels down, ideal when you want to work silently in libraries or coffee shops. This approach also decreases power consumption, and improves system reliability by avoiding potential dirt-related component failures.
  • Enjoy unique worlds of color and pixel-perfect video
    ASUS Splendid visual optimization technology provides excellent visuals for any type of content. It features four display modes: Normal mode is ideal for daily tasks; Vivid mode optimizes contrast to deliver stunning photos and video; Eye Care mode reduces blue-light levels to ease eye strain; and Manual mode allows for personalized color adjustments. ASUS Tru2Life Video technology intelligently optimizes each pixel in the video frame to increase sharpness and contrast by 150% so you'll enjoy outstanding image quality!
  • Fully optimized audio, tuned by experts
    ASUS SonicMaster and ASUS AudioWizard provide a perfect combination of hardware, software and audio tuning designed with the goal of giving you excellent audio experience. ASUS SonicMaster employs a professional-grade codec to ensure precise audio encoding and decoding, and uses amplifiers, large speakers and resonance chambers that are perfectly-suited for your specific device. ASUS AudioWizard is a powerful software suite that makes it easy to achieve the ideal audio balance for any type of content. It also offers manual settings possibilities, so you can take full control of your audio mix for truly immersive sound.
  • Stay cool - even after hours of use
    Laptop cooling is important because it directly affects your computing experience. ASUS IceCool technology uses thin heat pipes and clever internal layout design to create an efficient cooling system that keeps the average palm rest surface temperature below 36°C - lower than body temperature - so you get robust cooling performance and a comfortable user experience.
  • A safe fast-charging and longer-lasting battery
    E406 features a 3x the lifespan of standard lithium-ion batteries, giving you long hours of battery life so you can work out of coffee shops or libraries for the entire day without having to look out for a power socket. With ASUS fast-charge technology, a low battery can be charged to 60 percent very fast.
ASUS E406MA BV211TS - 14" - Celeron N4000 - 4 GB RAM - 64 GB eMMC
Notebook
Operating System
Windows 10 in S mode 64-bit
Intel Celeron N4000 / 1.1 GHz (2.6 GHz) / 4 MB Cache
4 GB (provided memory is soldered)
Storage
64 GB - eMMC
Optical Drive
No optical drive
Display
14" LED backlight 1366 x 768 / HD
Graphics
Intel UHD Graphics 600
Integrated Webcam
802.11b/g/n
3-cell - up to 14 hours
Iris blue
32.64 cm x 22.65 cm x 1.76 cm
1.3 kg
Environmental Standards
ENERGY STAR Qualified
Notebook
Operating System
Windows 10 in S mode 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
2.6 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
RAM
Storage
Main Storage
64 GB SSD - (eMMC)
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Anti-glare, 45% NTSC colour gamut, ASUS EyeCare Technology, Tru2Life, NanoEdge display
Audio & Video
Graphics Processor
Camera
Yes - VGA
Sound
Stereo speakers, microphone
Audio Features
ASUS SonicMaster, ASUS AudioWizard
Input
Keyboard, touchpad
Communications
Wireless
802.11b/g/n
3-cell
56 Wh
Run Time
Up to 14 hours
AC Adapter
Input
Output
33 Watt, 19 V, 1.75 A
Connections & Expansion
Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 , HDMI
Memory Card Reader
Yes (microSD)
Iris blue
ASUS IceCool design
Power adapter
UL, TUV, C-Tick, BSMI, CB, CCC, A-Tick, ErP 2013
1.3 kg
ENERGY STAR Certified
