Asus VivoBook Celeron N4000 4GB 64GB EMMC 14" Windows 10 Home - Star Grey
Quicklinx: F5VKWS00 Mfr#: E406MA-BV009TS
Display Size: 14in
Processor Model: N4000
Operating System: Windows 10 Home 64-bit Edition in S mode
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 64GB
  • Celeron
£194.50 ex VAT
£233.40 inc VAT
The E406 is designed to help you be productive all day - even when you're on the move. This compact and lightweight 14-inch laptop is powered by a high-performance processor and provides a long battery life. And with a NanoEdge display for immersive viewing, it's a great laptop for people on the go.
  • Take-anywhere portability
    E406 is extremely portable. It's an everyday laptop that keeps you productive and entertained - anywhere.
  • NanoEdge display
    With a thin bezel and 76.5% screen-to-body ratio, the NanoEdge display on E406 provides you with more screen area for more immersive viewing.
  • Fanless design with low operational noise
    The fanless design of the E406 keeps noise levels down, ideal when you want to work silently in libraries or coffee shops. This approach also decreases power consumption and improves system reliability by avoiding potential dirt-related component failures.
  • Fully optimized audio, tuned by experts
    ASUS SonicMaster and ASUS AudioWizard provide a perfect combination of hardware, software and audio tuning designed with the goal of giving you great audio experience. ASUS SonicMaster employs a professional-grade codec to ensure precise audio encoding and decoding, and uses amplifiers, large speakers and resonance chambers that are perfectly suited for your specific device. ASUS AudioWizard is a powerful software suite that makes it easy to achieve the ideal audio balance for any type of content. It also offers manual settings options, so you can take full control of your audio mix for truly immersive sound.
  • Stay cool - even after hours of use
    Laptop cooling is important because it directly affects your computing experience. ASUS IceCool technology uses thin heat pipes and clever internal layout design to create an efficient cooling system that keeps the average palm rest surface temperature below 36°C - lower than body temperature - so you get robust cooling performance and a comfortable user experience.
  • Safe fast charging and long-lasting battery
    E406 features 3x the lifespan of standard lithium-ion batteries, giving you up to 14 hours of battery life so you can work out of coffee shops or libraries for the entire day without having to look out for a power socket. With ASUS fast-charge technology, a low battery can be charged to 60 percent in just 49 minutes.
ASUS E406MA BV009TS - 14" - Celeron N4000 - 4 GB RAM - 64 GB eMMC
Notebook
Operating System
Windows 10 Home 64-bit in S mode
Intel Celeron N4000 / 1.1 GHz (2.6 GHz) / 4 MB Cache
4 GB LPDDR4 (provided memory is soldered)
Storage
64 GB - eMMC
Optical Drive
No optical drive
Display
14" LED backlight 1366 x 768 / HD
Graphics
Intel UHD Graphics 600
Integrated Webcam
802.11ac, Bluetooth 4.1
3-cell
Star grey IMR (LCD cover), starry grey painting (top)
32.64 cm x 22.65 cm x 1.76 cm
1.3 kg
Environmental Standards
ENERGY STAR Qualified
SAR
0.576 W/kg (body), 0.576 W/kg (limb)
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
2.6 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
LPDDR4 SDRAM
Storage
Main Storage
64 GB SSD - (eMMC)
Display
14"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
200 cd/m²
Anti-glare, 45% NTSC colour gamut, ASUS EyeCare Technology, Tru2Life, NanoEdge display
Audio & Video
Graphics Processor
Camera
Yes - VGA
Sound
Stereo speakers, microphone
Audio Features
ASUS SonicMaster, ASUS AudioWizard
Input
Keyboard, touchpad
Communications
Wireless
3-cell Lithium Ion
56 Wh
AC Adapter
Input
Output
33 Watt, 19 V, 1.75 A
Connections & Expansion
Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 , HDMI
Memory Card Reader
Yes (microSD)
ASUS IceCool design
Power adapter
UL, TUV, C-Tick, BSMI, CB, CCC, A-Tick, ErP 2013
SAR Value
1.3 kg
ENERGY STAR Certified
Display Size: 14in
Optical Storage: None
Graphics: Intel UHD Graphics 600
Hard Drive Type: SSD
Type: Laptop
Brand: Asus
Price Range Ex VAT: 150 - 300
