The ASUS VivoBook E12 is designed to help you be productive all day - even when you're on the move. This compact and lightweight 11.6-inch laptop is powered by the advanced processor and provides long hours of battery life. It's an excellent laptop for people on the go.
Designed for mobility
The VivoBook E12 offers effortless mobility, thanks to its compact and lightweight design. It's the perfect take-anywhere laptop, that's always ready to go where your day takes you. -
Durable 180° hinge
With its 180° hinge, the VivoBook E12 can be laid flat on the table to share content with friends and colleagues. -
Cinematic audiovisuals
ASUS Tru2Life video technology makes any video look amazing. Through intelligent algorithms, it optimizes the sharpness and contrast of every pixel in every frame to produce incredibly vivid and realistic imagery - every time! ASUS Splendid display technology optimizes imagery to provide richer, deeper and more accurate colors - for any type of content. The VivoBook E12 also delivers impressive audio, with dual speakers and ASUS SonicMaster technology for immersive surround-sound. -
Optimized battery for all-day computing
The VivoBook E12 is designed from the ground up for on-the-go users. You can work or watch movies without searching for power outlets. -
Faster, more stable Wi-Fi connections
The VivoBook E12 features dual-band 802.11ac Wi-Fi for strong, stable signals and fast data transmission speeds. As an added advantage, 802.11ac Wi-Fi is less prone to interference from other wireless devices, operating on the same bandwidth. -
Ultimate flexibility with USB-C
The reversible USB-C (Type C) port makes it easier to connect devices. USB 3.1 Gen 1 provides super-fast data transfer speeds! For maximum convenience and compatibility, the VivoBook E12 also features two standard USB 3.1 ports and one HDMI port. -
Ergonomic keyboard
A full-size, ergonomic keyboard with optimal key travel ensures supreme typing comfort. Typing on a compact device has never been this comfortable!
- ASUS VivoBook E12 E203NA FD020TS - 11.6" - Intel Celeron - N3350 - 2 GB RAM - 32 GB eMMC
- Product Type
- Notebook - 180-degree hinge design
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Celeron N3350 / 1.1 GHz, up to 2.4 GHz / 2 MB Cache
- Memory
- 2 GB DDR3 (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 11.6" LED backlight 1366 x 768 / HD
- Graphics
- Intel HD Graphics 500
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 2-cell
- Security
- Firmware Trusted Platform Module (TPM) Security Chip
- Pearl white
- 28.6 cm x 19.33 cm x 1.69 cm
- 980 g
- Specific Absorption Rate (SAR)
- 0.075 W/kg (body) , 0.075 W/kg (limb)
- Limited warranty - 1 year
- Product Type
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 2 GB (provided memory is soldered)
- Technology
- DDR3 SDRAM
Storage
- Main Storage
- 32 GB eMMC
Display
- 11.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Colour Gamut
- 45% NTSC
- ASUS Splendid Video Intelligence Technology, glare, Tru2Life
Audio & Video
- Graphics Processor
- Camera
- Yes - VGA
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower
Input
- Keyboard, touchpad
Communications
- Wireless
- Technology
- 2-cell lithium polymer
- Capacity
- 38 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 33 Watt, 19 V, 1.75 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , 2 x USB 3.1 , USB-C 3.1 Gen 1 , HDMI
- Memory Card Reader
- Yes (microSDXC)
- Pearl white
- Case Material
- Plastic
- Security
- Included Accessories
- Power adapter
- SAR Value
- 0.075 W/kg (body), 0.075 W/kg (limb)
- 980 g
Sustainability Information
- TCO Certified
