Asus VivoBook 15 X540UA Core i3-7020U 4GB 1TB HDD 15.6" Windows 10 Pro
Quicklinx: F30MWS00 Mfr#: X540UA-DM760R
Display Size: 15.6in
Processor Model: I3-7020U
Operating System: Windows 10 Pro, Windows 10 Pro
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 1TB
  • Core i3
£333.19 ex VAT
£399.82 inc VAT
ASUS VivoBook 15 is the perfect combination of beauty and performance. VivoBook 15 is powered by advanced processor and graphics. It boasts a dual-storage design that combines the fast data speeds of an SSD with the large capacities of an HDD, making it the ideal laptop for daily computing and entertainment.
  • Thinner and lighter
    ASUS VivoBook 15 is thinner and lighter. It's an everyday laptop with the weight and compactness of an ultrabook.
  • Amazing performance
    ASUS VivoBook 15 is powered by advanced processor and graphics for smooth visuals and great gaming experiences. It also features dual-band 802.11ac Wi-Fi - so you'll enjoy super-fast online performance.
  • Superfast data, large storage capacity
    The dual-storage design of the ASUS VivoBook 15 provides the best of both worlds - with blistering data speeds and large storage capacities. Install apps on the SSD for superfast response times, and use the HDD to house large files such as movies, music libraries and photo albums.
  • Complete connectivity
    A USB 3.1 port with a reversible USB Type-C connector makes connecting devices quick and easy. USB 3.1 provides high data transfer speeds. You can transfer photos, music and large video files in a fraction of the time.
  • Imagery-enhancing ASUS Splendid
    ASUS Splendid visual optimization technology provides amazing visuals for any type of content. It features four display modes which can be accessed with a single click.
  • Expansive audio, tuned by experts
    ASUS SonicMaster is a combination of hardware, software and audio tuning designed with the goal of giving you great audio experiences. A professional-grade codec ensures precise audio encoding and decoding, while amplifiers, large speakers and resonance chambers ensure powerful audio delivery and deeper bass. Additional signal processing and tuning help refine minute details filter noise and improve audio clarity - so you get truly immersive sound.
  • Stay cool - even after hours of use
    Laptop cooling is important because it directly affects your computing experience. ASUS IceCool technology uses smart fan control, thin heat pipes and clever design to create an efficient cooling system that keeps the average surface temperature of the palm rest lower than body temperature. This allows for robust cooling performance and ultimate user comfort.
ASUS VivoBook 15 X540UA-DM760R - 15.6" - Core i3 7020U - 4 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Pro
Intel Core i3 (7th Gen) 7020U / 2.3 GHz
4 GB DDR4 (provided memory is soldered)
Storage
1 TB HDD
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Integrated Webcam
802.11ac, Bluetooth 4.1
3-cell
Security
Firmware Trusted Platform Module (TPM) Security Chip
Chocolate black
38.1 cm x 25.1 cm x 2.72 cm
1.9 kg
Notebook
Operating System
Windows 10 Pro
Processor / Chipset
CPU
Number of Cores
Dual-Core
64-bit Computing
RAM
4 GB (provided memory is soldered)
Max RAM Supported
12 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
1 TB HDD SATA
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
ASUS Splendid Video Intelligence Technology, anti-glare, 45% NTSC colour gamut
Audio & Video
Graphics Processor
Camera
Yes - VGA
Sound
Stereo speakers, microphone
Audio Features
ASUS SonicMaster, ASUS AudioWizard
Input
Keyboard, touchpad
Communications
Wireless
3-cell
33 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
Headphone/microphone combo jack , USB 3.0 , HDMI , 2 x USB 2.0
Memory Card Reader
Yes (microSD)
Chocolate black
Security
System password, ASUS IceCool design
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
1.9 kg
Software applications
Asus VivoBook 15 X540UA Core i3-7020U 4GB 1TB HDD 15.6 Bundle deal on Asus VivoBook 15 X540UA Core i3-7020U 4GB 1TB HDD 15.6" Windows 10 Pro
£518.41
saving £8.33
£432.36
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: HDD
Type: Laptop
Brand: Asus
Price Range Ex VAT: 300 - 500
