With global resources becoming scarcer and the impact our demands have made on the planet becoming increasingly visible, green computing has become a critical issue in recent times. The VH192D LCD monitor adopts green power technology which uses just two lamps to save 28% power consumption and an advanced optical film to ensure brilliant image performance without sacrificing brightness.
18.5" 16:9 widescreen with HD resolution and anti-reflection glare panel enables borderless full-screen video display and more vibrant color performance.
ASCR (ASUS Smart Contrast Ratio) technology automatically adjusts the luminance of the backlight for better displays according to the image contents, and improves the contrast ratio to 10000:1 - resulting in more realistic depictions of night scenes during games or movies.
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life Full HD 1080p gaming or movie watching without any data loss or image distortion.
Splendid Video Intelligence technology adopts a color engine to detect activation and usage of video applications and automatically optimizes image quality with intelligent color, brightness, contrast and sharpness corrections for the best visual results. The Splendid offers 5 video modes designed for scenery, theater, gaming, night view, and standard images, 3 skin tones of yellowish, natural and reddish to add a human touch to videos on PC. You can see optimized images on screen and select five modes via hotkey quickly at your will.
Glare black frame and smooth base design create a fresh new look of LCD monitors Convenient key controls for functional set-up in the multi-language OSD. Cable manager gets rid of tangling cables and wires.
Delivers vibrant images with green power efficiency
With global resources becoming scarcer and the impact our demands have made on the planet becoming increasingly visible, green computing has become a critical issue in recent times. The VH192D LCD monitor adopts green power technology which uses just two lamps to save 28% power consumption and an advanced optical film to ensure brilliant image performance without sacrificing brightness. -
Vibrant and excellent visual quality
18.5" 16:9 widescreen with HD resolution and anti-reflection glare panel enables borderless full-screen video display and more vibrant color performance. -
ASCR (ASUS Smart Contrast Ratio) technology automatically adjusts the luminance of the backlight for better displays according to the image contents, and improves the contrast ratio to 10000:1 - resulting in more realistic depictions of night scenes during games or movies. -
Aspect Control
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life Full HD 1080p gaming or movie watching without any data loss or image distortion. -
Splendid Video Intelligence technology adopts a color engine to detect activation and usage of video applications and automatically optimizes image quality with intelligent color, brightness, contrast and sharpness corrections for the best visual results. The Splendid offers 5 video modes designed for scenery, theater, gaming, night view, and standard images, 3 skin tones of yellowish, natural and reddish to add a human touch to videos on PC. You can see optimized images on screen and select five modes via hotkey quickly at your will. -
Stylish and user-friendly design for modern sophistication
- Diagonal Size
- 18.5 in
- Max Resolution
- 1366 x 768
- Response Time
- 5 ms
- Speakers
- None
- VGA (HD-15)
- Black
- Aspect Ratio
- 16:9
- Dimensions & Weight / Depth
- 38.7 cm
- Dimensions & Weight / Height
- 21 cm
- Dimensions & Weight / Width
- 44.2 cm
- Display (Projector) / Dot Pitch / Pixel Pitch
- 0.3 mm
- Display (Projector) / Image Brightness
- 250 cd/m2
- Display (Projector) / Image Contrast Ratio
- 10000:1
- Header / Product Line
- ASUS
- Technology
- TFT active matrix
- Display (Projector) / Colour Support
- 24-bit (16.7 million colours)
- Display (Projector) / Colour Support (EA)
- 16.7 million colors
- Display (Projector) / Diagonal Size (metric)
- 47 cm
- Display (Projector) / Display Positions Adjustments
- Tilt
- Display (Projector) / Dynamic Contrast Ratio
- 10000:1
- Display (Projector) / Form Factor
- Desktop
- Display (Projector) / Image Max H-View Angle
- 170
- Display (Projector) / Image Max V-View Angle
- 160
- Display (Projector) / Type
- LCD display
- Display (Projector) / Widescreen
- Widescreen
- Header / Compatibility
- PC
- Header / Manufacturer
- ASUSTeK COMPUTER
- Header / Model
- VH192D
- Miscellaneous / Microsoft Certification
- Certified for Windows Vista
- Service & Support / Type
- 3 years warranty
- 3.7 kg
Bundle includes:
Microsoft Office 365 Business Premium ‘in a box’ 1 year subscription/license worth £99.76 | in stock |
