Lightning-fast response time
ASUS VG278Q boasts a fast response time to eliminate smearing and motion blur. This lets you react instantly to what you see on the screen, especially in fast-paced games. -
Incredible refresh rate
With an astonishing refresh rate, fast-moving visuals pose no problem for VG278Q. There's no frustrating lag, so you get the upper hand in first person shooters, racers, real-time strategy and sports titles. -
Flicker-free technology
Flicker-free technology reduces flicker to give you a comfortable gaming experience. This minimizes instances of eyestrain and other potentially damaging eye ailments when you're embroiled in long, drawn-out gaming sessions. -
Ergonomically designed
ASUS VG278Q is specially designed for long marathon gaming sessions. Its ergonomically designed stand lets you adjust the tilt, swivel, pivot, and height of the monitor so you always find your ideal viewing position.
- ASUS VG278Q - LCD monitor - Full HD (1080p) - 27"
- LCD monitor - 27"
- Energy Class
- Class F
- Power Consumption (On mode)
- 26.1 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, DVI-D, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Black
- 61.9 cm x 21.1 cm x 37.6 cm
- 5.6 kg
- UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, MEPS, J-MOSS, ErP Ready, E-Standby, UkrSEPRO, RCM, CEL level 1, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
- 3-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Energy Class
- Class F
- Diagonal Size
- 27"
- AMD FreeSync
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 40 - 144 Hz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), Smart View Technology, 5-way Navigation Key, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, ASUS GameVisual Technology, Colour Temperature Selection, GameFast Input Technology, 72% NTSC colour gamut
- Black
- 61.9 cm x 21.1 cm x 37.6 cm - with stand
- 5.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- HDMI , DisplayPort , DVI-D (dual link) , Audio line-in , Headphones
Mechanical
- Tilt Angle
- -5/+33
- Swivel Angle
- 180
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x audio cable
- 26.1 W
- Power Consumption SDR (On mode)
- 26.1 kWh/1000h
- Power Consumption (Typical)
- 40 Watt
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 61.9 cm - depth: 21.1 cm - height: 37.6 cm - weight: 5.6 kg , Without stand - width: 61.9 cm - depth: 5 cm - height: 36.3 cm - weight: 3.2 kg
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
