Asus VE248HR 24" Full HD 1080p Monitor - HDMI DVI-D VGA
Quicklinx: CW0HWS00 Mfr#: VE248HR
ASUS Smart Contrast Ratio dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p support and HDMI port. Quick response time of 1 ms (GTG) eliminates ghosting and tracers for more fluid video playback.
ASUS VE248HR - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
19 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2768 mm
Brightness
250 cd/m²
Contrast Ratio
10000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
56.94 cm x 20.1 cm x 40.97 cm
4.4 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, GOST-R, J-MOSS, ErP Ready, CEL level 2
3-year warranty
Display Type
Energy Class
Class A+
27 kWh
Diagonal Size
24"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2768 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, input select, colour temperature, aspect control
HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode
56.94 cm x 20.1 cm x 40.97 cm - with stand
4.4 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
VGA , DVI-D , HDMI , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x DVI cable , 1 x audio cable
19 W
Power Consumption (Typical)
35 Watt
Power Consumption Stand by
1 Watt
Power Consumption Sleep
1 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 56.94 cm - depth: 5.73 cm - height: 34 cm , With stand - width: 56.94 cm - depth: 20.1 cm - height: 40.97 cm - weight: 4.4 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
