ASUS Smart Contrast Ratio dynamically enhances the display's contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white - delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p support and HDMI port. Quick response time of 1 ms (GTG) eliminates ghosting and tracers for more fluid video playback.
- ASUS VE248HR - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A+
- Energy Consumption per Year
- 27 kWh
- Power Consumption (On mode)
- 19 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2768 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 10000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Black
- 56.94 cm x 20.1 cm x 40.97 cm
- 4.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, WEEE, GOST-R, J-MOSS, ErP Ready, CEL level 2
- 3-year warranty
- Display Type
- Energy Class
- Class A+
- 27 kWh
- Diagonal Size
- 24"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2768 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, input select, colour temperature, aspect control
- HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode
- Black
- 56.94 cm x 20.1 cm x 40.97 cm - with stand
- 4.4 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 1 Watt
- VGA , DVI-D , HDMI , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- Cables Included
- 1 x VGA cable , 1 x DVI cable , 1 x audio cable
- 19 W
- Power Consumption (Typical)
- 35 Watt
- Power Consumption Stand by
- 1 Watt
- Power Consumption Sleep
- 1 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - width: 56.94 cm - depth: 5.73 cm - height: 34 cm , With stand - width: 56.94 cm - depth: 20.1 cm - height: 40.97 cm - weight: 4.4 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
