Asus VB199TL 19" 1280 x 1024 5 ms DVI-D VGA Monitor
Quicklinx: CW32WS00 Mfr#: VB199TL
Diagonal Size: 19in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DVI, VGA (HD-15)
10 in stock
£129.16 ex VAT
£154.99 inc VAT
The 19" regular LED monitor VB199TL adopts advanced mercury-free and wide viewing angle LED-backlit panel to deliver many benefits of better visual details with high contrast ratio, energy saving with lower power consumption, and reduction of environmental pollution. VB199TL comes with an ergonomic design of height, tilt, swivel, and pivot adjustment for personal visual comfort.
  • 178┬░ultra wide viewing angle
    Come along with 178 degrees wide viewing angle LED panel to minimize the color shift from any viewing angle.
  • ASUS smart contrast ratio
    Adopt ASUS Smart Contrast Ratio (ASCR) technology to provide the high contrast ratio of 50000000:1, which can dynamically adjust contrast between black and white, and to create sharper and brighter images, especially during video and movies.
  • Splendid video intelligence technology
    The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes can be selected via a hotkey.
  • Versatile comfort with ergonomic design
    The ergonomically-designed VB199TL monitor comes with swivel, tilt, pivot, and height adjustments plus VESA wall-mount support for ideal viewing position.
ASUS VB199TL - LED monitor - 19"
LED-backlit LCD monitor - 19"
Power Consumption (On mode)
18.4 W
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
50000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
41.3 cm x 21.4 cm x 46.6 cm
4.7 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, PSB, FCC, RoHS, ISO 9241-307, WEEE, J-MOSS, TCO Displays 6.0
3-year warranty
Display Type
18.4 W
Diagonal Size
19"
Viewable Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.294 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
53 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, colour temperature
sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, 72% NTSC colour gamut, integrated cable management
41.3 cm x 21.4 cm x 46.6 cm - with stand
4.7 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
DVI-D , VGA , Audio line-in
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable , 1 x audio cable , 1 x DVI cable
Power Supply
Internal
17.1 Watt
Power Consumption Stand by
0.37 Watt
Power Consumption Sleep
0.35 Watt
Dimensions & Weight Details
Without stand - width: 41.3 cm - depth: 6.48 cm - height: 34.24 cm , With stand - width: 41.3 cm - depth: 21.4 cm - height: 46.6 cm - weight: 4.7 kg
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Diagonal Size: 19in
Response Time: 5ms
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 100 - 150
