The 19" regular LED monitor VB199TL adopts advanced mercury-free and wide viewing angle LED-backlit panel to deliver many benefits of better visual details with high contrast ratio, energy saving with lower power consumption, and reduction of environmental pollution. VB199TL comes with an ergonomic design of height, tilt, swivel, and pivot adjustment for personal visual comfort.
178°ultra wide viewing angle
Come along with 178 degrees wide viewing angle LED panel to minimize the color shift from any viewing angle. -
ASUS smart contrast ratio
Adopt ASUS Smart Contrast Ratio (ASCR) technology to provide the high contrast ratio of 50000000:1, which can dynamically adjust contrast between black and white, and to create sharper and brighter images, especially during video and movies. -
Splendid video intelligence technology
The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes can be selected via a hotkey. -
Versatile comfort with ergonomic design
The ergonomically-designed VB199TL monitor comes with swivel, tilt, pivot, and height adjustments plus VESA wall-mount support for ideal viewing position.
- ASUS VB199TL - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Power Consumption (On mode)
- 18.4 W
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 50000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- DVI-D, VGA
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 41.3 cm x 21.4 cm x 46.6 cm
- 4.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, TUV GS, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, TUV Ergo, PSB, FCC, RoHS, ISO 9241-307, WEEE, J-MOSS
- 3-year warranty
- Display Type
- Diagonal Size
- 19"
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.294 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 53 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, colour temperature
- sRGB colour management, HDCP, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, integrated cable management, 72% NTSC colour gamut
- Black
- 41.3 cm x 21.4 cm x 46.6 cm - with stand
- 4.7 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 watt
- DVI-D , VGA , Audio line-in
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable , 1 x audio cable , 1 x DVI cable
- Power Supply
- Internal
- Input Voltage
- 18.4 W
- Power Consumption (Typical)
- 17.1 watt
- Power Consumption Stand by
- 0.37 watt
- Power Consumption Sleep
- 0.35 watt
- Dimensions & Weight Details
- Without stand - width: 41.3 cm - depth: 6.48 cm - height: 34.24 cm , With stand - width: 41.3 cm - depth: 21.4 cm - height: 46.6 cm - weight: 4.7 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years ¦ Limited warranty - LCD panel - 3 years
