Brand
Asus VA247HE 23.8" HD 1920x1080 LED 5ms(GTG)
Quicklinx: GST7WS00 Mfr#: VA247HE
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DVI, HDMI, VGA
£82.90 ex VAT
£99.48 inc VAT
ASUS VA247HE Eye Care Monitor features 23.8-inch Full HD (1920 x 1080) 178° wide viewing angle panel, providing vivid image quality. Up to 75Hz refresh rate with Adaptive-Sync/FreeSync technology to eliminate tracing and ensure crisp and clear video playback. In addition, it also features TÜV Rheinland-certified Flicker-free and Low Blue Light technologies to ensure a comfortable viewing experience.
  • Viewing perfection
    You're treated to vibrant lifelike images thanks to its 3,000:1 high contrast ratio for darkest black and brightest white, and the 178° wide viewing angles panel for minimal distortion and color shift, even when you're viewing it from extreme positions.
  • Frameless design
    Makes it perfect for almost-seamless multi-display setups that give you an even greater degree of immersion.
  • Super smooth visuals with Adaptive-Sync/FreeSync
    Adaptive-Sync/FreeSync technology to eliminate screen tearing and choppy frame rates to give you seamless visuals and smooth gameplay. This gives you the upper hand in first person shooters, racing, real-time strategy and sports titles.
  • ASUS-exclusive GamePlus technology
    When it comes to design, ASUS always has customers in mind - ASUS exclusive GamePlus hotkey with Crosshair, Timer, FPS counter and Display Alignment functions to give you in-game enhancements that help you get more out of your game. This function is co-developed with input from pro gamers, allowing them to practice and improve their gaming skills.
  • ASUS-exclusive Splendid technologies
    Splendid Video Intelligence Technology optimizes videos and images by enhancing color brightness, contrast, and sharpness. Splendid features two innovative modes - Reading and Darkroom - in addition to the Scenery, Standard, Theater, sRGB, and Night View modes. Low-blue Light and Flicker-free technologies also reduce the strain on your eyes after long periods of use.
  • ASUS blue light filter
    Exclusive ASUS blue light filter protects you from harmful blue light. It's easy to access, intuitive and flexible with seamless adjustment (0 to maximum) via the OSD menu.
  • Flicker-free technology
    It's time to say goodbye to those tired, strained eyes. ASUS displays features TÜV Rheinland-certified ASUS Flicker-Free technology to reduce flicker for a comfortable viewing experience. This technology helps minimize instances of eyestrain and other damaging ailments, especially when you spend long, countless hours in front of a display watching favorite videos.
ASUS VA247HE - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class F
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
54.135 cm x 20.594 cm x 40.364 cm
3.25 kg
TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
Display Type
Energy Class
Class F
Diagonal Size
23.8"
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, ASUS Splendid Video Intelligence Technology, Trace Free Technology, ASUS QuickFit Virtual Scale, ASUS GamePlus, Flicker Free technology, Colour Temperature Selection, Low Blue Light technology, ASUS EyeCare+ Technology
54.135 cm x 20.594 cm x 40.364 cm - with stand
3.25 kg
HDMI , DVI , VGA
Mechanical
Tilt
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Input Voltage
22 kWh/1000h
Power Consumption (Typical)
17 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 54.135 cm - depth: 20.594 cm - height: 40.364 cm - weight: 3.25 kg , Without stand - width: 54.135 cm - depth: 4.944 cm - height: 32.541 cm - weight: 2.87 kg
Shipping Width
59.9 cm
Shipping Depth
12.7 cm
Shipping Height
41.5 cm
Shipping Weight
5.18 kg
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA
Brand: Asus
