A premium brushed aluminum finish
Buying an affordable laptop doesn't mean having to settle for something basic. ASUS EeeBook E403 gives you all the essentials you need for everyday computing. With its compact dimensions, streamlined curves, and brushed aluminum finish, EeeBook E403 provides you with an incredibly premium feel - far from what you'd expect for a value laptop. -
Thin and light
ASUS EeeBook E403 has an ultra-thin chassis and light weight, so you can take it with you wherever you go. -
USB Type-C
ASUS EeeBook E403 even features a USB Type-C port. It's reversible too, so it fits every time, right-side up, or upside down. -
Many hours of battery life
ASUS EeeBook E403 gives you many hours of battery life so you can work out of coffee shops or libraries for the entire day without having to look out for a power socket. It's great when you're traveling too, so you stay productive even on long haul flights. -
IceCool technology keeps you cool and comfortable
To keep heating issues at bay, ASUS IceCool technology employs a unique internal layout that keeps heat generating components away from the palm rest. This keeps palm rest surface at lower temperatures, so you stay comfortable for hours on end. -
A touchpad with smartphone touchscreen-like precision
Advanced technology used in the production of smartphone touchscreens has been incorporated into the touchpad of the ASUS EeeBook E403, giving you a highly sensitive surface for almost instantaneous response and incredible accuracy. The result - a more intuitive touchpad experience. Using the touchpad feels entirely natural, thanks to multi-touch and Smart Gesture input. Intuitive gestures lets you swipe and scroll through webpages or pinch-zoom in and out of images easily. -
Durable, full-size chiclet keyboard
The full-size chiclet keyboard features an improved design that allows for more accurate typing. It has little key float for a solid feel and more comfortable typing experience. -
Powerful CPU for efficient multi-tasking
ASUS EeeBook E403 features high-performance processors for the power to handle all your daily computing needs. Its smooth multi-tasking performance gives you the perfect platform for working, watching movies, surfing the web, or playing games. -
Fanless design with low operational noise
The fanless design of the ASUS EeeBook E403 keeps noise levels down, ideal when you want to work silently in libraries or coffee shops. -
ASUS Splendid technology for life-like visuals
ASUS EeeBook E403 delivers vibrant visuals and brilliant colors thanks to ASUS Splendid technology. This technology fine-tunes various display settings and parameters, ensuring you get amazing visuals. Whether you're watching movies or viewing photos, everything seems more real and life-like. -
High quality speakers with larger chambers
ASUS EeeBook E403 features high-quality dual speakers with larger speaker chambers situated under the palm rest. These direct sound towards you for a truly immersive experience as your favorite movies and music come to life.
- ASUS Vivo AiO V200IBUK - all-in-one - Celeron N3050 - 2 GB - HDD 500 GB - LED 19.5"
- Personal computer - all-in-one
- Processor
- Intel Celeron N3050 (Dual-Core)
- RAM
- 2 GB (installed) / 4 GB (max) - DDR3L SDRAM
- Storage Controller
- SATA
- Hard Drive
- HDD 500 GB - SATA - 7200 rpm
- Optical Storage
- No optical drive
- Card Reader
- 6 in 1
- Monitor
- 19.5" - LED - 1920 x 1080 (Full HD) - 16:9
- Graphics Controller
- Intel HD Graphics
- Audio Output
- Stereo
- Networking
- GigE, Wi-Fi
- OS Provided
- Windows 10 64-bit Edition
- Black
- 47.7 cm x 18.09 cm x 37.83 cm
- 7 kg
- Personal computer
- Product Form Factor
- All-in-one
- Black
Processor / Chipset
- CPU
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
RAM
- Installed Size
- 2 GB / 4 GB (max)
- Technology
- DDR3L SDRAM
- Effective Memory Speed
- 1600 MHz
Hard Drive
- HDD
- Capacity
- 1 x 500 GB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
Optical Storage
- No optical drive
Card Reader
- 6 in 1 card reader
- Supported Flash Memory Cards
- Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- LED
- Diagonal Size
- 19.5"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
Graphics Controller
- Graphics Processor
- Intel HD Graphics
- Video Interfaces
- HDMI
Audio Output
- Sound Output Mode
- Stereo
- Speakers Included
- 2 x right / left channel
Camera
- Resolution (MP)
- 1 Megapixel
Input Device
- Mouse, keyboard
Keyboard
- Connectivity
- Wireless
Mouse
- Connectivity
- Wireless
Audio Input
- Microphone
- Wireless LAN Supported
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, Wi-Fi
- Slots
- 1 (total) / 0 (free) x CPU
- 2 x USB 3.1 , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 4 x USB 3.0 , 1 x HDMI output , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Power adapter
- Power Provided
- 65 Watt
Operating System / Software
- OS Provided
- 47.7 cm
- 18.09 cm
- 37.83 cm
- 7 kg
