The stunningly beautiful ZenBook Pro UX501 features high-quality materials, advanced craftsmanship and high-performance components, ZenBook Pro has jaw-dropping style and breathtaking performance. The elegant design of the ZenBook family, with the iconic spun-metal finish, is subtly enhanced with brilliant diamond-cut highlights and brushed-metal surfaces that add a touch of sophistication. The elegant theme is continued in the stylish ripple-effect pattern laser-engraved on its surface. ZenBook Pro is more than an incredibly powerful laptop - it's a true work of art.
4K / UHD display brings every detail to life
The stunning 4K / UHD display gives your eyes a visual treat, whether you're reading text, viewing photos or watching videos. The amazing resolution makes photo or video editing so much easier, with every tiny detail pin-sharp and crystal-clear. And when you're web browsing, everything - even extremely small text - is easily visible. -
Breathtaking performance
At the heart of ZenBook Pro is the incredibly powerful processor, giving effortless performance for any task you can think of. With a massive RAM, ZenBook Pro gives you super-smooth multitasking and plenty of processing horsepower in reserve even for very intensive number-crunching tasks. ZenBook Pro will never run out of steam, whether you're manipulating multiple large office documents like spreadsheets and graphics-loaded presentations, watching 4K videos, rendering complex 3D graphics or simply relaxing with resource-hungry 3D games. -
Ultimate graphics for exclusive experience
Editing high-definition videos can be a frustrating task on an underpowered laptop. ZenBook Pro has all the ingredients needed to make sure your creativity isn't hampered by waiting: a powerful processor, lots of high-speed RAM, ultrafast flash storage and, of course, a high-performance graphics chip. The smooth, fluid and responsive graphics performance ensures your editing will flow, not stutter along. -
Long-lasting battery life
With ZenBook Pro's high-capacity lithium polymer battery and clever ASUS thermal engineering gives you long battery life even with its high-resolution 4K / UHD display - which is pretty impressive when you consider the amazing performance. ZenBook Pro is designed to be the perfect traveling companion: it turns on in an instant so it's always ready to go, and it lasts for many days in standby mode. Your data is always safe too, as ZenBook Pro automatically saves it to the hard disk if the battery charge level drops. -
A touch of precision
Touch is at the very heart of ZenBook Pro. Its ultra-responsive multi-touch display uses high-fidelity touch sensors that are much smaller and more sensitive than ordinary ones. This gives you instant, accurate touch performance for writing, drawing, navigating and more.
- ASUS ZENBOOK Pro UX501VW FY095R - 15.6" - Intel Core i7 - 6700HQ - 8 GB RAM - 256 GB SSD
- Product Type
- Ultrabook
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
- Memory
- 8 GB DDR4 (provided memory is soldered)
- Storage
- 256 GB SSD
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 960M
- Video Memory
- 2 GB
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 6-cell
- Aluminium silver
- 38.3 cm x 25.5 cm x 2.13 cm
- 2.06 kg
- Environmental Standards
- - ENERGY STAR Qualified EPEAT Climate+
- Limited warranty - 3 years - on-site
- Product Type
- Ultrabook
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM170
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (provided memory is soldered)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 SATA 6Gb/s
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Colour Gamut
- 72% NTSC
- Zero Bright Dot, Ultra Slim Design, ASUS Splendid Video Intelligence Technology, anti-glare, WideView
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB
- Camera
- Yes - HD
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: ASUS Bang & Olufsen ICEpower, ASUS SonicMaster Premium, ASUS AudioWizard
Input
- Keyboard, touchpad
- ASUS Smart Gesture technology
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Intel Wireless Display (WiDi)
- Technology
- 6-cell lithium polymer
- Capacity
- 96 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 120 Watt, 19 V, 6.3 A
Connections & Expansion
- Interfaces Details
- Headphone/microphone combo jack , USB-C Gen 2 (supports Thunderbolt 3) , 3 x USB 3.0 , HDMI , LAN (on supplied cable)
- Memory Card Reader
- 2 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
- Software Included
- 16 GB ASUS WebStorage (1 year)
- Aluminium silver
- Case Material
- Aluminum
- ASUS USB Charger+
- Included Accessories
- Power adapter, USB Gigabit Ethernet adapter
- UL, TUV, C-Tick, BSMI, CB, JATE, CCC, FCC, RoHS, A-Tick
- 2.06 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
- ENERGY STAR Certified
