Asus UX501VW-FY095R Core i7-6700HQ 8GB 256GB SSD Windows 10 Pro
INCLUDES 3 YEARS ON-SITE SUPPORT!
Quicklinx: C5BMWS00 Mfr#: UX501VW-FY095R-OSS
  • Core i7
  • Bluetooth 4.0
  • IEEE 802.11n
  • NVIDIA GeForce GTX 960M
The stunningly beautiful ZenBook Pro UX501 features high-quality materials, advanced craftsmanship and high-performance components, ZenBook Pro has jaw-dropping style and breathtaking performance. The elegant design of the ZenBook family, with the iconic spun-metal finish, is subtly enhanced with brilliant diamond-cut highlights and brushed-metal surfaces that add a touch of sophistication. The elegant theme is continued in the stylish ripple-effect pattern laser-engraved on its surface. ZenBook Pro is more than an incredibly powerful laptop - it's a true work of art.
  • 4K / UHD display brings every detail to life
    The stunning 4K / UHD display gives your eyes a visual treat, whether you're reading text, viewing photos or watching videos. The amazing resolution makes photo or video editing so much easier, with every tiny detail pin-sharp and crystal-clear. And when you're web browsing, everything - even extremely small text - is easily visible.
  • Breathtaking performance
    At the heart of ZenBook Pro is the incredibly powerful processor, giving effortless performance for any task you can think of. With a massive RAM, ZenBook Pro gives you super-smooth multitasking and plenty of processing horsepower in reserve even for very intensive number-crunching tasks. ZenBook Pro will never run out of steam, whether you're manipulating multiple large office documents like spreadsheets and graphics-loaded presentations, watching 4K videos, rendering complex 3D graphics or simply relaxing with resource-hungry 3D games.
  • Ultimate graphics for exclusive experience
    Editing high-definition videos can be a frustrating task on an underpowered laptop. ZenBook Pro has all the ingredients needed to make sure your creativity isn't hampered by waiting: a powerful processor, lots of high-speed RAM, ultrafast flash storage and, of course, a high-performance graphics chip. The smooth, fluid and responsive graphics performance ensures your editing will flow, not stutter along.
  • Long-lasting battery life
    With ZenBook Pro's high-capacity lithium polymer battery and clever ASUS thermal engineering gives you long battery life even with its high-resolution 4K / UHD display - which is pretty impressive when you consider the amazing performance. ZenBook Pro is designed to be the perfect traveling companion: it turns on in an instant so it's always ready to go, and it lasts for many days in standby mode. Your data is always safe too, as ZenBook Pro automatically saves it to the hard disk if the battery charge level drops.
  • A touch of precision
    Touch is at the very heart of ZenBook Pro. Its ultra-responsive multi-touch display uses high-fidelity touch sensors that are much smaller and more sensitive than ordinary ones. This gives you instant, accurate touch performance for writing, drawing, navigating and more.
ASUS ZENBOOK Pro UX501VW FY095R - 15.6" - Intel Core i7 - 6700HQ - 8 GB RAM - 256 GB SSD
Ultrabook
Operating System
Win 10 Pro 64-bit
Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
8 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
Video Memory
2 GB
Keyboard Backlight
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
6-cell
Aluminium silver
38.3 cm x 25.5 cm x 2.13 cm
2.06 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - 3 years - on-site
Ultrabook
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
Max Turbo Speed
3.5 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Chipset
Mobile Intel HM170
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (provided memory is soldered)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Colour Gamut
72% NTSC
Zero Bright Dot, Ultra Slim Design, ASUS Splendid Video Intelligence Technology, anti-glare, WideView
Audio & Video
Graphics Processor
Video Memory
2 GB
Camera
Yes - HD
Sound
Stereo speakers, microphone
Audio Features
Output: ASUS Bang & Olufsen ICEpower, ASUS SonicMaster Premium, ASUS AudioWizard
Input
Keyboard, touchpad
Keyboard Backlight
ASUS Smart Gesture technology
Communications
Wireless
Network Interface
Gigabit Ethernet
Intel Wireless Display (WiDi)
6-cell lithium polymer
96 Wh
AC Adapter
Input
Output
120 Watt, 19 V, 6.3 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , USB-C Gen 2 (supports Thunderbolt 3) , 3 x USB 3.0 , HDMI , LAN (on supplied cable)
Memory Card Reader
2 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
Software
Software Included
16 GB ASUS WebStorage (1 year)
Aluminium silver
Case Material
Aluminum
ASUS USB Charger+
Power adapter, USB Gigabit Ethernet adapter
UL, TUV, C-Tick, BSMI, CB, JATE, CCC, FCC, RoHS, A-Tick
2.06 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
