Asus UX305CA Intel Core M3-6Y30 8GB 128GB SSD 13.3" Win 10
Quicklinx: BZF0WS00 Mfr#: UX305CA-FB005T
  • IEEE 802.11n
  • Bluetooth 4.0
ZenBook UX305CA is designed to go everywhere you go. But it's not just an amazingly-beautiful, lightweight laptop: it's seriously powerful too, packed with the latest high-performance technology. With ZenBook UX305CA, you can do all the incredible things you've always wanted to do, wherever you are.
The sophisticated design of ZenBook UX305CA is a masterpiece of craftsmanship, engineered to stand out from the crowd. It takes dozens of precisely-controlled manufacturing steps to forge each ZenBook UX305CA from a raw block of solid aluminum. The subtle and refined shape incorporates the DNA of the classic ZenBook, with an elegantly-tapered wedge design that's both practical and elegant.
ZenBook UX305CA has a display that looks just as good as you'd expect from such a beautiful laptop. The ultra-sharp touchscreen has an amazing up to QHD+ resolution of 3200 by 1800 pixels, so it's always easy and comfortable to view. And with an incredible pixel density of 276 pixels per inch, images and text are always pin-sharp and ultra-detailed.
Developed by the ASUS Golden Eye team, exclusive ASUS Splendid technology gives you vivid, accurate colors no matter what you're watching. It works by automatically fine-tuning various display settings to optimize all kinds of images. The result is richer, deeper colors and stunning visuals whether you're watching videos and movies, playing games or browsing through your photos.
ZenBook UX305CA lets you work in blissful silence. The combination of the power-efficient Intel Core M processor and a lot of clever engineering means that it doesn't need a fan to keep cool. Instead, ASUS get rid of the heat efficiently using a high-tech, ultra-thin 0.5mm-diameter heatpipe made from a special chromium-copper alloy.
ZenBook UX305CA's powerful battery and intelligent power management keep it working for up to 10 hours with Wi-Fi connected. So when you want to unwind after a tough day, there'll always be plenty of power in hand for play!
ASUS-exclusive IceCool technology prevents heat build-up on the palm rest, keeping it within a temperature range of 28?C to 35?C. This is well below body temperature, giving you a much more comfortable and relaxing typing experience than conventional laptops.
The full-size, one-piece chiclet keyboard is a masterpiece of ergonomics, with an improved design featuring a long 1.5mm of key travel and minimal key float. The result? A solid feel and a more comfortable experience, even for those marathon typing sessions.
ZenBook UX305CA's three USB 3.0 ports speed transfers up to ten times (10X) faster than older USB 2.0 connections, and deliver more power for faster charging. And ZenBook UX305CA goes still further, with ASUS USB Charger+ technology built into one port to charge connected devices up to 50% faster - even when ZenBook is asleep or switched off.
Incredible sound has always been a feature of the ZenBook family, and ZenBook UX305CA is no exception. ASUS SonicMaster technology - tuned by the renowned ASUS Golden Ear team - uses a combination of precision engineering and software to deliver sound like you've never heard before from a laptop, with deep rich bass and crystal-clear vocals, even at the highest volume levels.
  • A slim, featherweight powerhouse
  • Embodying the spirit of Zen
  • Lifelike color with ASUS Splendid technology
  • Fanless cooling: Enjoy the silence
  • Up to 10 hours battery life
  • Stay chilled with ASUS IceCool
  • Outstanding ergonomics
  • Powerful connections
  • ASUS SonicMaster: designed to sound incredible
ASUS ZENBOOK UX305CA-FB005T - 13.3" - Intel Core m3 - 6Y30 - 8 GB RAM - 128 GB SSD
Ultrabook
Operating System
Win 10 Home 64-bit
Intel Core m3 (6th Gen) - 6Y30
8 GB (provided memory is soldered)
Storage
128 GB SSD
Display
13.3" LED backlight 3200 x 1800 / QHD+ - 276 ppi
Graphics
Intel HD Graphics 515
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
3-cell
32.4 cm x 22.6 cm x 1.23 cm
1.2 kg
Environmental Standards
- ENERGY STAR Qualified
Ultrabook
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Intel Core m3 (6th Gen) 6Y30
Number of Cores
Dual-Core
64-bit Computing
RAM
Storage
Main Storage
128 GB SSD M.2 SATA 6Gb/s
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
3200 x 1800 (QHD+)
Widescreen
Pixel Density (ppi)
276
Image Aspect Ratio
16:9
ASUS Splendid Video Intelligence Technology
Audio & Video
Graphics Processor
Camera
Yes - 720p
Image Sensor Type
CMOS
Sound
Speaker, microphone
Audio Features
Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower
Input
Keyboard, touchpad
Multi-touch touchpad, ASUS Smart Gesture technology
Communications
Wireless
3-cell lithium polymer
AC Adapter
Input
Output
45 Watt, 19 V
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , 3 x USB 3.0 , Micro-HDMI
Memory Card Reader
2 in 1 (SD Card, SDHC Card, SDXC Card)
Software
Software Included
16 GB ASUS WebStorage (1 year)
Case Material
Aluminum
ASUS IceCool design, ASUS USB Charger+
Power adapter
UL, TUV, CCC, FCC, RoHS, WEEE
1.2 kg
Sustainability Information
TCO Certified
ENERGY STAR Certified
