The ASUS USB-N13's specially-designed internal antenna provides you consistent transmission and wide coverage. The WPA/WPA2 enterprise encryption enables you to access corporate certificate-based authentication network, ensure that you to communicate under fast and high protected environment.
Xlink Kai is a free software that enables PSP gamers to play system-link games via the Internet instead of via the local area network (LAN). You just enable "PSP Xlink Mode" on ASUS utility, and then wirelessly game with faraway players through Xlink server.
When you are in business trip, when you like to share your internet access, the USB-N13 build-in software AP enables you to create a small WLAN environment and connect to the internet via ICS (Internet Connection Sharing). Its ACL (Access Control List) and ICS (Internet Connection Sharing) let you easily manage your access authority and quickly turns your PC into a Wireless AP, flexible and convenient.
Simply insert USB-N13 into your computer's USB port and press the WPS button on both the router and USB-N13. Within two steps, a secure and protected wireless connection setting done!
The USB-N13 supports you multiple OS driver to easily go freedom wireless on most aboveground OS.
300Mbps Pro N - secure and excellent connection
The ASUS USB-N13's specially-designed internal antenna provides you consistent transmission and wide coverage. The WPA/WPA2 enterprise encryption enables you to access corporate certificate-based authentication network, ensure that you to communicate under fast and high protected environment. -
PSP Xlink Kai support
Xlink Kai is a free software that enables PSP gamers to play system-link games via the Internet instead of via the local area network (LAN). You just enable "PSP Xlink Mode" on ASUS utility, and then wirelessly game with faraway players through Xlink server. -
Software AP 2-in-1 device for wireless connection sharing
When you are in business trip, when you like to share your internet access, the USB-N13 build-in software AP enables you to create a small WLAN environment and connect to the internet via ICS (Internet Connection Sharing). Its ACL (Access Control List) and ICS (Internet Connection Sharing) let you easily manage your access authority and quickly turns your PC into a Wireless AP, flexible and convenient. -
EZ WPS Wi-Fi setup - simply insert, simply connect
Simply insert USB-N13 into your computer's USB port and press the WPS button on both the router and USB-N13. Within two steps, a secure and protected wireless connection setting done! -
Support Multiple OS - Windows, Mac and Linux
- ASUS USB-N13 - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Linux, Microsoft Windows 2000, Apple MacOS X 10.3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- 300 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
- Frequency Band
- 2.4 GHz
- Max Range Open Space
- 150 m
- Status Indicators
- Power, link/activity
- Software access point, Wi-Fi Protected Setup (WPS)
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Encryption Algorithm
- WPA, WPA2-Enterprise
- Software Included
- Drivers & Utilities
- OS Required
