Asus USB-AC51 Dual-Band Wireless-AC600 Wi-Fi adapter
Quicklinx: B6BSWS00 Mfr#: USB-AC51
Wired / Wireless: Wireless
Protocol: IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g + 1 more
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
  • IEEE 802.11n
Hurry, only 3 left in stock!
£27.78 ex VAT
£33.33 inc VAT
The easy way to add next-generation 802.11ac Wi-Fi to notebook and desktop PCs
ASUS USB-AC51 is the smallest 802.11ac USB Wi-Fi adapter for you to instantly upgrade your desktop and notebook to the next generation 5G Wi-Fi with hassle-free setup. Its specially-designed internal antenna provides wireless speed up to up to 150Mbps at 2.4 GHz and 433 Mbps at 5 GHz. It supports multiple OS including Windows, Mac OS X, and Linux. The transmission quality and excellent features make USB-AC51 a great choice for simultaneous downloads, online gaming, and video streaming.
Next gen 802.11ac wireless, up to 3X faster than previous wireless N adapters
The fastest Wi-Fi ever becomes more accessible via USB, going up to 433 Mbps on the clear 5 GHz band. Using 802.11ac wireless, faster connectivity and enjoyment come to all your devices. Compared with current 802.11n, the USB-AC51 delivers up to 433 Mbps at 5 GHz, which is 3X faster than 802.11n.
*Quoted network speeds and bandwidth based on current IEEE 802.11ac specifications. Actual performance may be affected by network and service provider factors, interface type, and other conditions. Connected devices must be 802.11ac-compatible for best results.
Selectable dual-band 433 Mbps/150Mbps bandwidth
Dual-band operation suits mainstream and power users. The 2.4 GHz band is perfect for web browsing, email, and social networking, while the 5 GHz frequency enables smooth HD streaming and online multiplayer for blazingly fast and lag-free home entertainment.
Smallest 802.11ac Wi-Fi adapter for easy connection and instant upgrade for PCs
The world's most compact wireless USB adapter measures just 3cm long. It's easy to carry and fits in pockets, yet offers strong wireless. With its USB interface, the USB-AC51 gives your desktop and notebook an instant 802.11ac Wi-Fi upgrade, with access to speeds of up to 433 Mbps.
  • The easy way to add next-generation 802.11ac Wi-Fi to notebook and desktop PCs
    ASUS USB-AC51 is the smallest 802.11ac USB Wi-Fi adapter for you to instantly upgrade your desktop and notebook to the next generation 5G Wi-Fi with hassle-free setup. Its specially-designed internal antenna provides wireless speed up to up to 150 Mbps at 2.4 GHz and 433 Mbps at 5 GHz. It supports multiple OS including Windows, Mac OS X, and Linux. The transmission quality and excellent features make USB-AC51 a great choice for simultaneous downloads, online gaming, and video streaming.
  • Next gen 802.11ac wireless, up to 3x faster than previous wireless N adapters
  • Selectable dual-band 433 Mbps/150 Mbps bandwidth
  • Smallest 802.11ac Wi-Fi adapter for easy connection and instant upgrade for PCs
ASUS USB-AC51 - network adapter
Network adapter
External
Interface (Bus) Type
USB 2.0
3.098 cm x 1.6 cm x 0.864 cm
4 g
802.11ac
Data Transfer Rate
583 Mbps
Frequency Band
2.4 GHz, 5 GHz
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac
Linux, Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4, Microsoft Windows Vista, Apple MacOS X 10.6, Apple MacOS X 10.5, Ubuntu, Apple MacOS X 10.7 Lion, Windows 8, Apple MacOS X 10.8, Windows 8.1
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Data Transfer Rate
583 Mbps
Frequency Band
2.4 GHz, 5 GHz
IPv6 support, RADIUS support, Wi-Fi Protected Setup (WPS), 802.1x authentication
Aerial
Antenna
Internal
Antenna Qty
2
Gain Level
4.56 dBi
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
Software Included
Drivers & Utilities
3.098 cm
1.6 cm
0.864 cm
4 g
Limited warranty - parts and labour - 2 years
Protocol: IEEE 802.11ac
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Brand: Asus
Price Range Ex VAT: 0 - 50
