ASUS TUF Z270 Mark 2 LGA1151 DDR4 HDMI DVI M.2 USB 3.1 Z270 ATX Motherboard
- Designed for 7th generation LGA 1151 socket Intel® Core™ processors
- Maximize your connectivity and speed with integrated Dual M.2 slots with Intel® Optane™ Memory compatibility, front panel USB 3.0 and rear USB 3.1 Type A connections
- Dual Patent-pending SafeSlots featuring an injection molding process that integrates metal framing for a stronger, firmly anchored PCIe slot built for heavyweight GPUs
- Thermal Armor and Thermal Radar Core PLUS provide superior cooling control during intense overclocking sessions
- Ultimate Protection 5-Year Warranty for guaranteed reliability built on Military Grade engineering
Total stability, guaranteed compatibility
TUF is where ambition for reliably brilliant performance meets reality. When you build a system using the TUF Z270 Mark 2 motherboard, you build with the confidence of total stability and guaranteed compatibility. And with TUF Z270 Mark 2, the digital-camouflage concept even further - by stenciling the military-inspired digital pattern directly onto the board! Evocative of might, TUF Z270 Mark 2's stunning the aesthetic envisions the future for your next battle-ready rig. Whether you want to work or mod, be sure to build on a solid foundation with The Ultimate Force - that's TUF! -
Qualified Vendor List (QVL)
TUF Z270 Mark 2 is carefully engineered to work seamlessly with a wide range of high-performance workstation graphics cards. The ASUS promise of great compatibility is backed by the comprehensive Qualified Vendor List that includes leading brands and products - so you can be certain of compatibility before you buy that perfect graphics card. -
Engineered for maximum memory acceleration
Implementing a engineering-intensive DRAM layout, the 3rd generation ASUS T-Topology delivers the DDR4-overclocking dynamics that let you push memory frequencies further than ever - all the way up to 3866 MHz if all memory slots are being utilized! -
One click to overclock
You don't need to be a technical expert to experience exhilarating overclocking performance with TUF Z270 Mark 2, because Thermal Radar Core+ now incorporates the Fast Tuning feature for efficient operation with precise voltage control and monitoring - all managed with a single click! -
Thermal Radar Core+
ASUS TUF Thermal Radar Core+ enables complete system cooling management - quickly, easily and safely. Customizable controls allow you to easily adjust fan speeds, so temperature can be tuned with just a single click. And for more single-click simplicity, the Live Update feature ensures that Thermal Radar Core+ is never out of date.
- ASUS TUF Z270 MARK 2 - motherboard - ATX - LGA1151 Socket - Z270
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z270
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 2 x M.2
- USB / FireWire Ports
- 2 x USB 3.1 + 4 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1 GB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z270
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3400 MHz (O.C.), 3333 MHz (O.C.), 3466 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3866 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1 GB
Audio
- Audio Codec
- Realtek ALC887
- High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 2 x PCIe 3.0 x16 (dual x8 mode; single card: x16 mode) , 1 x PCIe 3.0 x16 (x2 mode) , 3 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x M.2
- RAID Features
- Intel Smart Response Technology
- 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.1 , 4 x USB 3.0 , 2 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x DVI-D , 1 x TOSLINK
- Internal Interfaces
- 4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x serial - header , 1 x SPDIF out - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, UEFI BIOS, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support, ACPI 6.0 support
- Hardware Features
- C.P.R. (CPU Parameter Recall), jack retasking, MemOK!, ASUS Q-Design, TUF Engine!, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, Intel Extreme Memory Profile (XMP) support, NVIDIA 2-way SLI Technology Support, Intel Turbo Boost Technology 2.0, AMD CrossFireX technology support, Ultimate COOL!, Safe & Stable! Guardian Angel, Turbo LAN, TUF ESD Guards 2, TUF LANGuard, TUF Components, ASUS SafeSlot, 3D printing friendly, Intel Optane Memory Ready, ASUS 4 + 2 Digital Phase Power Design, TUF Thermal Radar Core+
- Included Accessories
- 1 x M.2 screw, TUF stickers
- Cables Included
- 2 x Serial ATA cable , 1 x SLI bridge
- Software Included
- ASUS AI Charger, ASUS AI Suite III, ASUS Turbo App, Cloud GO!
- Plug and Play
- 30.5 cm
- 23.4 cm
