Asus TUF Gaming Ryzen 5 3550H 8GB 256SSD 15.6" Windows 10
Quicklinx: FFQNWS00 Mfr#: FX505DT-AL086T
Display Size: 15.6in
Processor Model: 3550H
Operating System: Windows 10 Home 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
£691.33 ex VAT
£829.59 inc VAT
Experience smoother, more immersive gameplay with the advanced ASUS TUF Gaming FX505. Featuring an amazing IPS-level NanoEdge display with great technology and a refresh rate up to 120Hz, and armed with a robust processor and discrete graphics, it delivers high-performance gaming at an affordable price.
  • Extreme immersion on a fast display
    The NanoEdge design has a slim bezel for extremely engaging visuals in a much more compact package. FX505 features an ultra-fast IPS-level panel for super smooth gameplay with minimal motion blur. Wide-view technology ensures consistent colors when you're viewing the screen from extreme angles.
  • Tougher than standard
    Infused with the spirit of TUF, the FX505 passes a series of rigorous tests, successfully surviving varying conditions including solar radiation exposure, high altitude, and temperature extremes. Durable and stable, FX505 has been pushed to the limit to ensure only the very best for gamers.
  • Desktop-inspired RGB-backlit keyboard
    FX505 has a keyboard that's optimized for gaming, featuring RGB backlighting across all zones that can be controlled via the TUF Aura Core panel so you can express your own unique style. Exclusive HyperStrike technology ensures more accurate typing and improved ergonomics thanks to a desktop-inspired layout with a highlighted WASD key group, broader space bar, isolated arrow keys, and recognizable gaps between the function keys.
  • Game-ready performance
    Despite its compact size, FX505 packs the punch of a full-fledged gaming desktop. It's powered by a fast processor. The processor allows for faster, more efficient multitasking, including simultaneous gaming, recording, and live streaming.
  • HyperCool technology improves durability
    ASUS-exclusive HyperCool technology consists of the ADC system and HyperFan to ensure exceptional cooling during gaming marathons. Cooling is also improved by the patented trapezoid-cut lid and intelligent parallel fan placement.
  • Immersive DTS surround sound
    DTS Headphone:X technology delivers immersive, high-fidelity 7.1-channel virtual surround-sound for theater-quality audio, even when you're using a headset. It features optimized settings for games, sports, and movies, and has a built-in equalizer for additional fine-tuning.
  • I/O ports within easy reach
    FX505 features a host of I/O ports including a single USB 2.0 and two USB 3.1 Gen 1 Type-A ports for your gaming peripherals, as well as HDMI 2.0 to connect to an external display. All ports are situated on the left side of the laptop so there's nothing to interfere with right-handed mousing.
ASUS TUF Gaming FX505DT AL086T - 15.6" - Ryzen 5 3550H - 8 GB RAM - 256 GB SSD
Notebook
Operating System
Win 10 Home 64-bit
AMD Ryzen 5 3550H / 2.1 GHz (3.7 GHz) / 4 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB SSD NVMe
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA GeForce GTX 1650
Video Memory
4 GB GDDR5 SDRAM
Keyboard Backlight
Yes (RGB)
Integrated Webcam
Bluetooth, 802.11ac, Gigabit Ethernet
3-cell
36 cm x 26.2 cm x 2.6 cm
2.2 kg
SAR
0.1 W/kg (body), 0.1 W/kg (limb)
Notebook
Operating System
Processor / Chipset
CPU
Max Turbo Speed
3.7 GHz
Number of Cores
Quad-Core
Cache
4 MB
64-bit Computing
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2) PCIe - NVM Express (NVMe)
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Bezel Type
Raised
Anti-glare, 45% NTSC colour gamut, 120 Hz refresh rate, 62.5% sRGB colour gamut, 170° viewing angle, 47.1% Adobe RGB colour gamut
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Video System Features
NVIDIA Optimus
Camera
Yes - 720p
Sound
Stereo speakers, array microphone
Input
Keyboard, touchpad
Keyboard Backlight
Yes (RGB)
Chiclet keyboard
Communications
Wireless
Bluetooth, 802.11ac
Network Interface
Gigabit Ethernet
3-cell Lithium Ion
48 Wh
AC Adapter
Input
Output
150 Watt, 20 V, 7.5 A
Connections & Expansion
Headphone/microphone combo jack , USB 2.0 , 2 x USB 3.1 Gen 1 , LAN , HDMI
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
SAR Value
2.2 kg
Optical Storage: None
Graphics: NVIDIA GeForce GTX 1650
Hard Drive Type: SSD
Type: Gaming Laptop
Brand: Asus
Price Range Ex VAT: 500 - 750
