The ultra-thin, feather-light, 10.1-inch ASUS Transformer Mini is two amazing devices in one! Built from magnesium-aluminum alloy, it's a 10.1-inch ultraportable 2-in-1 with long hours of battery life.
The best materials, for the best mobility
Built from strong but incredibly light magnesium-aluminum alloy, Transformer Mini is ultra-thin and feather-light, with a tablet that's just 8.2 mm thin and weighs a mere 530 g! Even with the keyboard attached, it's still a slender 13.9 mm thin and light weight, so you'll never have an excuse to leave your Transformer Mini at home. Working (or playing! ) on the go has never been so easy. -
Convenient Smart Hinge design
Using a Smart Hinge design that gives the stepless kickstand up to 170° of movement, Transformer Mini lets you adjust the display to any angle you wish. So wherever you're using Transformer Mini - in the office, at home, or on your lap - you can always work or play in total comfort. Take Transformer Mini, wherever you go! -
Easy one-touch access
They wanted to make Transformer Mini always ready to use at any time, so we've given it a clever auto-scanning fingerprint sensor- Instant ID. This supports the Windows Hello feature, so you can unlock Transformer Mini instantly with just a single touch! -
Enjoy brighter and clearer watching experience
Transformer Mini T102HA looks amazing, and so does its gorgeous HD display. With up to 400 cd/m2 brightness, and thanks to 178° wide viewing display technology you can enjoy bright, vivid and clear images from almost any angle! The dual side-mounted stereo speakers create an immersive surround-sound effect, and exclusive ASUS Tru2Life video enhancement and TruVivid direct-bonding technology make sure you always see the best possible images, with sharp, realistic videos and fewer annoying reflections. -
Small, slim and productive
Transformer Mini is truly comfortable and intuitive to use. A brand-new ultra-slim keyboard design makes it even more compact and light. But they haven't compromised usability - the precision touchpad has palm-rejection technology and Windows gesture support, and the keyboard has 1.5mm key travel, making it a real pleasure to use. Typing on the go has never been this comfortable, and the keyboard's fiberglass anti-dust construction keeps it always looking great! -
Amazing all-day battery life
When you have a busy mobile lifestyle, great battery life is essential. With long hours between charges, you can be sure that Transformer Mini T102HA will be right there whenever you need it. You can charge T102HA via its micro USB port, so you can use a mobile charger or any power bank with a micro USB connector. With T102HA, traveling is a pleasure, not a chore! -
Faster, more reliable Wi-Fi
Transformer Mini T102HA features the latest dual-band 802.11ac Wi-Fi technology for strong, stable signals and faster data speeds than previous generations of Wi-Fi. It's less prone to interference from other wireless devices, too, so you can stream high-definition movies and videos smoothly without stuttering. -
More efficient, more intelligent with Quick Launch
Transformer Mini features the Quick Launch feature that makes your mobile life even easier. With a simple on-screen gesture or swipe, you can launch your favorite apps, wake up Transformer Mini or put it into sleep mode. It's easier than ever to work with Transformer Mini!
- ASUS Transformer Mini T102HA GR036T - 10.1" - Intel Atom x5 - Z8350 - 4 GB RAM - 128 GB eMMC
- Product Type
- Tablet - with keyboard dock
- Operating System
- Windows 10 Home
- Processor
- Intel Atom x5 Z8350 / 1.44 GHz, up to 1.92 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 128 GB eMMC
- Display
- 10.1" LED backlight touchscreen 1280 x 800 / WXGA
- Graphics
- Intel HD Graphics
- Input Device
- Keyboard, touchpad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 2-cell - up to 11 hours
- Dockable
- Security
- Fingerprint reader
- Quartz grey
- Dimensions (WxDxH) - tablet
- 25.9 cm x 17 cm x 0.82 cm
- 540 g
- Environmental Standards
- - EPEAT Climate+
- Specific Absorption Rate (SAR)
- 1.578 W/kg (body) , 1.578 W/kg (limb)
- Product Type
- Operating System
- Windows 10 Home
Processor / Chipset
- CPU
- Max Turbo Speed
- 1.92 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 128 GB eMMC
Display
- 10.1" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1280 x 800 (WXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
- Colour Gamut
- 60% NTSC
- Ultra Slim Design, ASUS Splendid Video Intelligence Technology, WideView, ASUS TruVivid technology, ASUS EyeCare Technology
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Resolution
- 2 Megapixel
- Camera Features
- Windows Hello
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: ASUS SonicMaster, ASUS AudioWizard
Input
- ASUS Smart Gesture technology
Communications
- Wireless
- Technology
- 2-cell lithium polymer
- Capacity
- 32 Wh
- Run Time
- Up to 11 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 9 V, 2 A
Connections & Expansion
- Interfaces Details
- Micro-HDMI , Headphone/microphone combo jack , USB 3.0 , Micro-USB 2.0 , Dock
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
- Quartz grey
- Case Material
- Plastic
- Dockable
- Security
- Included Accessories
- Power adapter
- UL, C-Tick, BSMI, CB, JATE, CCC, MIC, FCC, RoHS, A-Tick, GOST-R, iDA, ErP 2013
- SAR Value
- 1.578 W/kg (body), 1.578 W/kg (limb)
- 540 g
- Dimensions (WxDxH) / Weight Details
- 25.9 cm x 17 cm x 1.39 cm / 790 g - tablet with keyboard , 25.9 cm x 17 cm x 0.82 cm / 540 g - tablet
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
