Asus Transformer Z8350 4GB 128GB 10.1" Touch Windows 10
Quicklinx: CWGYWS00 Mfr#: T102HA-GR036T
  • IEEE 802.11n
The ultra-thin, feather-light, 10.1-inch ASUS Transformer Mini is two amazing devices in one! Built from magnesium-aluminum alloy, it's a 10.1-inch ultraportable 2-in-1 with long hours of battery life.
  • The best materials, for the best mobility
    Built from strong but incredibly light magnesium-aluminum alloy, Transformer Mini is ultra-thin and feather-light, with a tablet that's just 8.2 mm thin and weighs a mere 530 g! Even with the keyboard attached, it's still a slender 13.9 mm thin and light weight, so you'll never have an excuse to leave your Transformer Mini at home. Working (or playing! ) on the go has never been so easy.
  • Convenient Smart Hinge design
    Using a Smart Hinge design that gives the stepless kickstand up to 170° of movement, Transformer Mini lets you adjust the display to any angle you wish. So wherever you're using Transformer Mini - in the office, at home, or on your lap - you can always work or play in total comfort. Take Transformer Mini, wherever you go!
  • Easy one-touch access
    They wanted to make Transformer Mini always ready to use at any time, so we've given it a clever auto-scanning fingerprint sensor- Instant ID. This supports the Windows Hello feature, so you can unlock Transformer Mini instantly with just a single touch!
  • Enjoy brighter and clearer watching experience
    Transformer Mini T102HA looks amazing, and so does its gorgeous HD display. With up to 400 cd/m2 brightness, and thanks to 178° wide viewing display technology you can enjoy bright, vivid and clear images from almost any angle! The dual side-mounted stereo speakers create an immersive surround-sound effect, and exclusive ASUS Tru2Life video enhancement and TruVivid direct-bonding technology make sure you always see the best possible images, with sharp, realistic videos and fewer annoying reflections.
  • Small, slim and productive
    Transformer Mini is truly comfortable and intuitive to use. A brand-new ultra-slim keyboard design makes it even more compact and light. But they haven't compromised usability - the precision touchpad has palm-rejection technology and Windows gesture support, and the keyboard has 1.5mm key travel, making it a real pleasure to use. Typing on the go has never been this comfortable, and the keyboard's fiberglass anti-dust construction keeps it always looking great!
  • Amazing all-day battery life
    When you have a busy mobile lifestyle, great battery life is essential. With long hours between charges, you can be sure that Transformer Mini T102HA will be right there whenever you need it. You can charge T102HA via its micro USB port, so you can use a mobile charger or any power bank with a micro USB connector. With T102HA, traveling is a pleasure, not a chore!
  • Faster, more reliable Wi-Fi
    Transformer Mini T102HA features the latest dual-band 802.11ac Wi-Fi technology for strong, stable signals and faster data speeds than previous generations of Wi-Fi. It's less prone to interference from other wireless devices, too, so you can stream high-definition movies and videos smoothly without stuttering.
  • More efficient, more intelligent with Quick Launch
    Transformer Mini features the Quick Launch feature that makes your mobile life even easier. With a simple on-screen gesture or swipe, you can launch your favorite apps, wake up Transformer Mini or put it into sleep mode. It's easier than ever to work with Transformer Mini!
ASUS Transformer Mini T102HA GR036T - 10.1" - Intel Atom x5 - Z8350 - 4 GB RAM - 128 GB eMMC
Tablet - with keyboard dock
Operating System
Windows 10 Home
Intel Atom x5 Z8350 / 1.44 GHz, up to 1.92 GHz / 2 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
128 GB eMMC
Display
10.1" LED backlight touchscreen 1280 x 800 / WXGA
Graphics
Intel HD Graphics
Input Device
Keyboard, touchpad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
2-cell - up to 11 hours
Dockable
Security
Fingerprint reader
Quartz grey
Dimensions (WxDxH) - tablet
25.9 cm x 17 cm x 0.82 cm
540 g
Environmental Standards
- EPEAT Climate+
1.578 W/kg (body) , 1.578 W/kg (limb)
Operating System
Windows 10 Home
Processor / Chipset
CPU
Max Turbo Speed
1.92 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz
Storage
Main Storage
128 GB eMMC
Display
10.1" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (10-point multi-touch)
Resolution
1280 x 800 (WXGA)
Widescreen
Image Aspect Ratio
16:10
Colour Gamut
60% NTSC
Ultra Slim Design, ASUS Splendid Video Intelligence Technology, WideView, ASUS TruVivid technology, ASUS EyeCare Technology
Audio & Video
Graphics Processor
Intel HD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Resolution
2 Megapixel
Camera Features
Windows Hello
Sound
Stereo speakers, microphone
Audio Features
Output: ASUS SonicMaster, ASUS AudioWizard
Input
Keyboard, touchpad
ASUS Smart Gesture technology
Communications
Wireless
2-cell lithium polymer
32 Wh
Run Time
Up to 11 hours
AC Adapter
Input
Output
9 V, 2 A
Connections & Expansion
Interfaces Details
Micro-HDMI , Headphone/microphone combo jack , USB 3.0 , Micro-USB 2.0 , Dock
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Quartz grey
Case Material
Plastic
Dockable
Security
Fingerprint reader
Power adapter
UL, C-Tick, BSMI, CB, JATE, CCC, MIC, FCC, RoHS, A-Tick, GOST-R, iDA, ErP 2013
SAR Value
1.578 W/kg (body), 1.578 W/kg (limb)
540 g
Dimensions (WxDxH) / Weight Details
25.9 cm x 17 cm x 1.39 cm / 790 g - tablet with keyboard , 25.9 cm x 17 cm x 0.82 cm / 540 g - tablet
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
