Asus Transformer Book T100TA-DK002H 10.1" Touch Atom Z3740 2GB 32GB Win 8.1
Quicklinx: 92RXWS00 Mfr#: T100TA-DK002H
  • Atom
  • Windows 8.1 32-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
2-in-1 ultraportable laptop with 10" tablet
  • Windows 8.1 & Microsoft Office Home & Student 2013 with full versions of Word, Excel, PowerPoint and OneNote
  • Small and light, with an IntelĀ® quad-core processor
  • Comfortable keyboard dock and IPS display
  • Up to 11 hours battery life for all-day mobile use
Transformer Book T100 is a compact ultraportable that combines the productivity features of a laptop with the easy portability of a tablet - and you can switch between the two in an instant. At just 1.07kg, T100 is one of the lightest laptops around, but detach the 10.1-inch display from the keyboard and it becomes an equally lightweight multi-touch tablet you can take anywhere. The sleek design features a durable finish, too, so T100 will always look its best.
  • The ultraportable transformed
    Transformer Book T100 is a compact ultraportable that combines the productivity features of a laptop with the easy portability of a tablet - and you can switch between the two in an instant. T100 is one of the lightest laptops around, but detach the 10.1-inch display from the keyboard and it becomes an equally lightweight multi-touch tablet you can take anywhere. The sleek design features a durable finish, too, so T100 will always look its best.
  • High-performance productivity
    Transformer Book T100 is powered by the Intel Atom quad-core processor for perfect balance of multi-tasking performance and outstanding energy efficiency. Large eMMC storage makes launching apps and saving files speedy, too, while USB 3.0 supports SuperSpeed storage devices for turbo-charged data transfers.
  • Stay unplugged for longer
    Just press the power button and T100 is ready for use in just two seconds, so there's no waiting around when it's time to work - or play. There's no need to worry about data loss if T100 is left unused for longer, either. Data is also backed up automatically when the battery level drops to 5% in standby mode, so you won't be in for a nasty surprise when you next switch on.
  • The dock that rocks
    Transformer Book T100 isn't just a tablet with a keyboard dock - it's designed from the get-go to be a fully functional laptop. The dock also features USB 3.0 with full support for high-speed storage devices, while a micro-HDMI port on tablet means you can connect T100 to a Full HD TV for big-screen entertainment.
  • Serious sound quality
    Developed by the team of experts in the ASUS Golden Ear team, SonicMaster audio technology uses a tailored mix of hardware and software to enhance sound quality to a level far above what you might expect from so small a laptop. Stereo speakers with large resonance chambers give rich, rounded bass and sophisticated audio processing tools boost the frequency range to make music, movies and games sound fantastic.
  • A screen that's easy on the eyes
    Taking a tablet to bed is one way to catch up on some reading, but it's not always advisable. Bright light can dazzle in a dark environment and the high-energy visible light emitted by traditional computer displays has been linked to age-related macular degeneration. Transformer Book T100 features a special 'reading mode' to help avoid this. When activated, it automatically adjusts the screen settings to reduce the amount of high-frequency blue/violet light to create a more comfortable reading experience.
  • Enhance your entertainment
    Transformer Book T100 features a beautiful 10.1-inch IPS HD display that brings all your photos, videos and games to life. And thanks to T100's amazing sound and incredibly light weight, it's absolutely perfect for entertainment on the move.
ASUS Transformer Book T100TA-DK002H - 10.1" - Intel Atom - Z3740 - 2 GB RAM - 32 GB eMMC
Tablet - with keyboard dock
Operating System
Win 8.1 32-bit
Intel Atom Z3740 / 1.33 GHz (1.86 GHz) / 2 MB Cache
2 GB LPDDR3
Storage
32 GB eMMC
Display
10.1" LED backlight touchscreen 1366 x 768 / HD
Graphics
Intel HD Graphics
Input Device
Keyboard, touchpad
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0
2-cell - up to 11 hours
26.3 cm x 17.1 cm x 1.05 cm
523 g
Environmental Standards
ENERGY STAR Qualified
SAR
0.533 W/kg (body), 0.533 W/kg (limb)
Operating System
Processor / Chipset
CPU
Max Turbo Speed
1.86 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
Intel Burst Technology
RAM
2 GB
LPDDR3 SDRAM
Speed
1067 MHz
Storage
Main Storage
32 GB eMMC
Display
10.1" - IPS
LCD Backlight Technology
LED backlight
Touchscreen
Yes (multi-touch)
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Glare, WideView
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Resolution
1.2 Megapixel
Sound
Stereo speakers, microphone
Audio Features
Output: ASUS SonicMaster
Input
Keyboard, touchpad
Communications
Wireless
2-cell lithium polymer
31 Wh
Run Time
Up to 11 hours
AC Adapter
Output
10 Watt, 5 V, 2 A
Connections & Expansion
Micro-HDMI , Headphone/microphone combo jack , Micro-USB 2.0 , USB 3.0 (on keyboard dock)
Memory Card Reader
Yes (microSD)
InstantOn, ASUS Super Hybrid Engine II
UL, C-Tick, BSMI, CB, JATE, CCC, MIC, FCC, RoHS, A-Tick, GOST-R, iDA, ErP 2013
SAR Value
523 g
Dimensions (WxDxH) / Weight Details
17.1 cm x 1.05 cm / 523 g - tablet , 507 g - clamshell
Sustainability Information
ENERGY STAR Certified
