Asus Transformer 3 13.3" M3-7Y30 4GB 256GB Windows 10 - Titanium Grey
Quicklinx: D147WS00 Mfr#: T305CA-GW015T
  • IEEE 802.11n
When you look at ASUS Transformer 3, you’re seeing evolution in action. Crafted from the finest materials and expertly engineered to be as thin and light as possible, ASUS Transformer 3 gives you ultimate mobility, total convenience, and amazing expandability — giving you endless possibilities! Be creative with the ASUS Pen. Enjoy music with the Audio Pod. Game with ROG XG Station 2. Be productive with the Universal Dock. Do more. Do it better. Do it with ASUS Transformer 3.
The best materials, exquisitely engineered
ASUS Transformer 3 is a stunning example of the art of engineering. The gorgeous tablet is carved from solid aluminum in a process that takes over 100 stages of computer-controlled cutting. This advanced material is so strong and light that it’s enabled us to produce an awe-inspiring 6.9mm-thin device that weighs only 695g. But it doesn’t end there: we give it a beautiful spun-metal finish before adding the finishing touches — the brilliant diamond-cut edge highlights. It’s your device, created with our passion.
Create your perfect style
If you’re struggling to find a device with looks that say "Me!", we’ve some great news for you. With ASUS Transformer 3, we’re introducing a completely new approach to color, with eight unique color combinations to choose from. There are two gorgeous device colors — sophisticated Icicle Gold and high-tech Titanium Gray — plus four trendy color options for the ASUS Transformer Sleeve Keyboard, so you can mix and match to get the perfect theme for your lifestyle.
Pixels, perfected
The 12.6-inch display on ASUS Transformer 3 is truly remarkable. Not only does it offer superb detail with its 3K (2880 by 1920 pixels) resolution and 275ppi pixel density, but it has an extra-wide color gamut of 121% sRGB and 85% NTSC. If that’s too many acronyms for you, it simply means that ASUS Transformer 3 can display more-accurate colors — and more-vivid colors — than most of its rivals, which in turn means that images look much more natural and realistic. Whatever you create, is what you see.
A vivid visual experience
ASUS Transformer 3 features several exclusive ASUS technologies designed to enhance your viewing experience. ASUS Tru2Life Video uses intelligent software algorithms to optimize the sharpness and contrast of every pixel in every video frame — that’s over one million calculations per second — so that videos look clearer, more detailed and more realistic. Eye-Care mode reduces the amount of harmful blue light emitted from the screen by up to 30%, for added protection and comfort for your eyes. ASUS TruVivid is the name of our direct-bonding technology, which does away with some light-sapping glass layers to improve clarity and reduce reflections by up to 67%.
Four speakers, extraordinary sound
When it comes to audio, ASUS Transformer 3 is unlike any other laptop or tablet. It has no less than four powerful speakers — each with the largest voice coils in their class — combined with our smart amplifier technology to deliver awesome full-bodied immersive sound. And that’s not all — clever algorithms allows ASUS Transformer 3 to automatically adjust the direction of the sound, so whatever the position of the tablet, you’ll always hear the optimum sound quality.
The power to create
Create anything effortlessly with 7th Gen Intel® Core™ i7 processors and 8GB of fast LPDDR3 RAM let you blast through the toughest tasks. Its Thunderbolt™ 3 interface offers unbelievably fast 40Gbps data transfers via the USB-C port — that’s 80 times faster than USB 2.0 — and also supports external 4K UHD displays. And that’s not all: the versatile, any-way-up USB-C connector also supports USB 3.1 Gen 2 devices at speeds up to 10Gbps, 20 times faster than USB 2.0! Amazing performance isn’t quite so amazing if the battery gives up, so ASUS Transformer 3 gives you all-day battery life — enough to keep you going throughout a busy working day and enjoyable night-time entertainment. And even when it’s finally time for a charge, you won’t be kept waiting: its fast-charge technology means that you can top the battery up to 60% in just 50 minutes!
  • Thunderbolt and the Thunderbolt logo are trademarks of Intel Corporation in the U.S. and/or other countries.
Connect to a different reality
ASUS Transformer 3 has some truly revolutionary capabilities, such as the ability to connect to the ROG XG Station 2 external graphics dock via its Thunderbolt™ 3 interface. This means you can add desktop-grade gaming graphics — using up to an NVIDIA® GeForce® GTX™ 1080 GPU — with all the power you need for the latest games and even virtual reality (VR) applications.
One-touch access
With a single touch on ASUS Transformer 3’s built-in fingerprint sensor, you can unlock your ASUS Transformer 3 in just a second with no need to type in a password! It’s a secure, quick and amazingly convenient way to access all your personal stuff.
A keyboard like no other
ASUS Transformer 3 has an innovative ASUS Transformer Sleeve Keyboard that also supports ASUS Transformer 3 at two different angles, so you can easily adjust it to suit your posture. Whether you’re standing, sitting, or sharing, you can always find the perfect position. This slim keyboard has other secrets, too. It has a laptop-quality backlit keyboard with 1.4mm key travel for ultra-comfortable typing. It also has a large glass-covered touchpad that gives you higher sensitivity and more precise control, as well as support for multi-touch Windows gestures.
Little box, big connections
Connecting to all your devices at home or in the office is easy with ASUS Transformer 3’s Universal Dock. It has all the ports you need, including an SD card reader, LAN, VGA, HDMI, USB 3.0 and USB-C.
Capture. Write. Create.
ASUS Transformer 3 is designed to let your creativity and productivity flow, however you interact with it. Using the high-precision ASUS Pen, you can jot down your notes and ideas, annotate photos that you’ve taken with one of Transformer 3’s two cameras (yes, there are two: a 13MP rear camera and a 5MP front camera!), or simply enjoy being creative! Whatever you want to do, ASUS Transformer 3 makes it easier.
  • Great materials, exquisitely engineered
    ASUS Transformer 3 is a stunning example of the art of engineering. The gorgeous tablet is carved from solid aluminum in a process that takes over 100 stages of computer-controlled cutting. This advanced material is so strong and light that it's enabled to produce an awe-inspiring thin device that is extremely lightweight. But it doesn't end there: a beautiful spun-metal finish is given before adding the finishing touches - the brilliant diamond-cut edge highlights.
  • Pixels, perfected
    The 12.6-inch display on ASUS Transformer 3 is truly remarkable. Not only does it offer superb detail with its 3K (2880 by 1920 pixels) resolution and 275ppi pixel density, but it has an extra-wide color gamut of 121% sRGB and 85% NTSC. If that's too many acronyms for you, it simply means that ASUS Transformer 3 can display more-accurate colors - and more-vivid colors - than most of its rivals, which in turn means that images look much more natural and realistic. Whatever you create, is what you see.
  • A vivid visual experience
    ASUS Transformer 3 features several exclusive ASUS technologies designed to enhance your viewing experience. ASUS Tru2Life Video uses intelligent software algorithms to optimize the sharpness and contrast of every pixel in every video frame - that's over one million calculations per second - so that videos look clearer, more detailed and more realistic. Eye-Care mode reduces the amount of harmful blue light emitted from the screen by up to 30%, for added protection and comfort for your eyes. ASUS TruVivid is the name of the direct-bonding technology, which does away with some light-sapping glass layers to improve clarity and reduce reflections by up to 67%.
  • Four speakers, extraordinary sound
    When it comes to audio, ASUS Transformer 3 is unlike any other laptop or tablet. It has no less than four powerful speakers - each with the largest voice coils in their class - combined with the smart amplifier technology to deliver awesome full-bodied immersive sound. And that's not all - clever algorithms allows ASUS Transformer 3 to automatically adjust the direction of the sound, so whatever the position of the tablet, you'll always hear the optimum sound quality.
  • Awesome sound, unleashed
    If you want to make ASUS Transformer 3 sound even better - for that blockbuster movie you're streaming, perhaps - it's easy. Just connect the optional Bluetooth Audio Pod to take things to the next level of awesome, with four powerful extra speakers to create an unforgettable audio experience.
  • Designed to let your creativity flow
    Intuitive, natural and effortless: that's how your interactions with ASUS Transformer 3 should be. And with the high-precision ASUS Pen, you have it. Jot down your notes and ideas, annotate photos or simply indulge your artistic creativity. Whatever you want to do, ASUS Transformer 3 is always ready for you.
ASUS Transformer 3 T305CA GW015T - 12.6" - Intel Core m3 - 7Y30 - 4 GB RAM - 256 GB SSD
Tablet - with detachable keyboard
Operating System
Win 10 Home 64-bit
Intel Core m3 (7th Gen) - 7Y30 / 1 GHz, up to 2.6 GHz / 4 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
256 GB SSD
Display
12.6" LED backlight touchscreen 2880 x 1620 / WQHD+ - 275 ppi
Graphics
Intel HD Graphics 615
Input Device
Keyboard, touchpad, stylus
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
2-cell
Security
Trusted Platform Module (TPM) Security Chip, fingerprint reader
Titanium grey
30.2 cm x 20.2 cm x 0.69 cm
700 g
Environmental Standards
- EPEAT Climate+
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Intel Core m3 (7th Gen) 7Y30 / 1 GHz
Max Turbo Speed
2.6 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
256 GB SSD M.2 SATA 6Gb/s
Display
12.6"
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
2880 x 1620 (WQHD+)
Widescreen
Pixel Density (ppi)
275
Image Aspect Ratio
16:9
Image Brightness
450 cd/m²
Colour Gamut
121% sRGB, 85% NTSC
Glare, WideView, ASUS TruVivid technology, ASUS EyeCare Technology, Tru2Life
Audio & Video
Graphics Processor
Camera
Resolution
13 Megapixel (rear), 5 Megapixel (front)
Sound
Harman/kardon stereo speakers, microphone
Audio Features
Output: ASUS SonicMaster Premium
Input
Keyboard Backlight
Communications
Wireless
2-cell lithium polymer
39 Wh
AC Adapter
Input
Output
45 Watt, 19 V, 2.37 A
Connections & Expansion
Interfaces Details
Headphone/microphone combo jack , USB-C Gen 2 (supports Thunderbolt 3) , Dock
Titanium grey
Security
Stylus, power adapter, keyboard
700 g
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
