By carefully trimming every last gram of excess weight, the lightest Flip ever was created. At a feather-light 1.2kg, TP200 is the perfect take-anywhere device that's ready to go wherever your day takes you. It's always to hand for work, for sharing or for simply relaxing.
Flip TP200's gorgeous metal finish makes it lovely to touch, and its stylish looks make it stand out from the crowd. But Flip TP200 doesn't just look and feel good: the scratch-resistant texture is amazingly tough and durable too, helping to keep its elegant beauty unblemished.
Flip TP200's robust and remarkable 360-degree, multi-gear metal hinge gives you the freedom to organize your life the way you want. Do serious work in laptop mode. Flip into tent mode to share or discuss stuff with your colleagues. Create your own personal movie theater in an instant with stand mode. And wherever you are, Flip's handy tablet mode is enhanced by the lightweight design and superb battery life.
The reversible USB Type-C port makes connecting devices so much easier, and its compact design allows Flip TP200 to be thinner than ever. Fast USB 3.1 Gen 1 (up to 5Gbit/s) lets you transfer a 2GB movie to a USB drive in under 2 seconds! For maximum convenience and compatibility, TP200 also has standard USB 3.0 and USB 2.0 ports, plus a micro HDMI port for connecting an external display.
Lighter than ever
By carefully trimming every last gram of excess weight, the lightest Flip ever was created. At a feather-light 1.2kg, TP200 is the perfect take-anywhere device that's ready to go wherever your day takes you. It's always to hand for work, for sharing or for simply relaxing. -
Expressive elegance
Flip TP200's gorgeous metal finish makes it lovely to touch, and its stylish looks make it stand out from the crowd. But Flip TP200 doesn't just look and feel good: the scratch-resistant texture is amazingly tough and durable too, helping to keep its elegant beauty unblemished. -
Solid engineering, from any angle
Flip TP200's robust and remarkable 360-degree, multi-gear metal hinge gives you the freedom to organize your life the way you want. Do serious work in laptop mode. Flip into tent mode to share or discuss stuff with your colleagues. Create your own personal movie theater in an instant with stand mode. And wherever you are, Flip's handy tablet mode is enhanced by the lightweight design and superb battery life. -
Reversible USB Type-C port, connect faster & easier
The reversible USB Type-C port makes connecting devices so much easier, and its compact design allows Flip TP200 to be thinner than ever. Fast USB 3.1 Gen 1 (up to 5Gbit/s) lets you transfer a 2GB movie to a USB drive in under 2 seconds! For maximum convenience and compatibility, TP200 also has standard USB 3.0 and USB 2.0 ports, plus a micro HDMI port for connecting an external display. -
Instant response to the lightest touch
Flip TP200 is designed to respond instantly to your every touch. The touch sensitivity has been doubled, so even the slightest movement of your fingertips is detected, and it only needs the lightest of touches to work perfectly. In fact, it's so good that it reacts accurately even to a child's small fingertips! -
Typing comfort is all in the details
Just because the 11.6 -inch Flip TP200 is incredibly slim, light and compact doesn't mean you have to suffer typing on it. A superb keyboard was engineered with full-size keys, and with just the right amount of key travel to make it supremely comfortable to use, even for marathon typing stints. The cleverly-designed key mechanism gives the keys a reassuringly-solid feel - it's details like this that set Flip TP200 apart from the crowd. -
A responsive touchpad that's smart
The large touchpad on Flip TP200 makes it effortless to navigate your way around Windows. It was made extra-sensitive for instant response, and to avoid those annoying jumps when your palm hits the touchpad, an exclusive smart algorithm is used that recognizes the difference between fingers and a palm. It's a perfect balance between sensitivity and usability. -
A clear view, from any angle
Wide viewing angles ensure that images never look washed out or lacking in contrast, even when viewing them from off-center. This makes Flip TP200 perfect for sharing screen contents with a group of people, whatever mode Flip is in.
- ASUS Transformer Book Flip TP200SA-FV0108TS - 11.6" - Intel Celeron - N3050 - 2 GB RAM - 32 GB eMMC
- Product Type
- Notebook - flip design
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Celeron N3050 / 1.6 GHz, up to 2.16 GHz / 2 MB Cache
- Memory
- 2 GB DDR3L (provided memory is soldered)
- Storage
- 32 GB eMMC
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- 2-cell - up to 8 hours
- Security
- Trusted Platform Module (TPM) Security Chip
- Dark blue metal with straight hairline (LCD cover), plastic with IMR in dark blue (top)
- 29.7 cm x 20.1 cm x 1.85 cm
- 1.2 kg
- Product Type
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.16 GHz
- Number of Cores
- Dual-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 2 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
Storage
- Main Storage
- 32 GB eMMC
Display
- 11.6" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 200 cd/m²
- Colour Gamut
- 50% NTSC
- Glare, WideView
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Yes - VGA
- Sound
- Stereo speakers, microphone
- Audio Features
- Output: ASUS SonicMaster
Input
- Keyboard, touchpad
Communications
- Wireless
- Technology
- 2-cell lithium polymer
- Capacity
- 38 Wh
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 33 Watt, 19 V, 1.75 A
Connections & Expansion
- USB 3.0 , USB 2.0 , USB-C , Headphone/microphone combo jack , Micro-HDMI
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
- Case Material
- Metal
- Security
- Scratch-resistant
- Included Accessories
- Power adapter
- UL, C-Tick, BSMI, CB, JATE, CCC, MIC, FCC, RoHS, A-Tick, GOST-R, iDA, ErP 2013
- 1.2 kg
