Asus T101HA x5 Z8350 4GB 64GB eMMC 10.1" Win 10 Pro
Quicklinx: CW89WS00 Mfr#: T101HA-GR029R
For effortless mobility and productivity, Transformer Book T101HA is very compact. Even with the keyboard attached, T101HA is still a very travel-friendly. With a device this compact and light, you'll never have an excuse to leave it at home. Transformer Book T101HA's reversible hinge makes it even more versatile! Detach and flip the tablet, then reattach it for two fantastic modes. Exclusive ASUS Tru2Life Video and TruVivid technologies ensure amazing images in any situation, with sharp, realistic videos and fewer annoying reflections.
  • Your slim and ultra-light mobile companion
  • Multiple modes with brighter, sharper, clear, viewing experience
  • Amazing all-day battery life
    When you have a busy mobile lifestyle, great battery life is essential. You can be sure that Transformer Book T101HA will be right there whenever you need it. You can charge T101HA via its micro USB port, so you can use a mobile charger or any power bank with a micro USB connector. With T101HA, traveling is a pleasure, not a chore!
  • Every connection you need
    Even though Transformer Book T101HA is incredibly slim and light, it has all the ports you need to connect devices on the go, including USB, micro USB, micro HDMI, micro SD and a headphone jack. And even better, all these ports are on the tablet, so they're always available. T101HA is small, but big on connectivity!
  • Faster, more reliable Wi-Fi
    Transformer Book T101HA features the dual-band 802.11ac Wi-Fi technology for strong, stable signals. It's less prone to interference from other wireless devices, too, so you can stream high-definition movies and videos smoothly without stuttering.
  • Maximum comfort, minimum size
    Its precision touchpad has palm-rejection technology, and the ergonomic keyboard has 1.5 mm key travel with a tactile bounce force, making it a real pleasure to use. Typing on a compact device has never been this comfortable!
ASUS Transformer Book T101HA GR029R - 10.1" - Atom x5 Z8350 - 4 GB RAM - 64 GB eMMC
Tablet - with keyboard dock
Operating System
Win 10 Pro 64-bit
Intel Atom x5 Z8350 / 1.44 GHz (1.92 GHz) / 2 MB Cache
4 GB DDR3 (provided memory is soldered)
Storage
64 GB eMMC
Display
10.1" LED backlight touchscreen 1280 x 800 / WXGA
Graphics
Intel HD Graphics 400
Input Device
Keyboard, touchpad
Integrated Webcam
802.11ac, Bluetooth 4.1
2-cell - up to 11 hours
Security
Trusted Platform Module (TPM) Security Chip
Glacier grey
Dimensions (WxDxH) - tablet
26.1 cm x 17.5 cm x 0.9 cm
580 g
Environmental Standards
ENERGY STAR Qualified
SAR
0.856 W/kg (body), 0.856 W/kg (limb)
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
1.92 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
DDR3 SDRAM
Storage
Main Storage
64 GB SSD eMMC
Display
10.1"
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1280 x 800 (WXGA)
Widescreen
Image Aspect Ratio
16:10
Image Brightness
400 cd/m²
Ultra Slim Design, ASUS Splendid Video Intelligence Technology, glare, WideView, 60% NTSC colour gamut, ASUS TruVivid technology, Tru2Life
Audio & Video
Graphics Processor
Camera
Resolution
2 Megapixel
Sound
Stereo speakers, microphone
Audio Features
ASUS SonicMaster
Input
Keyboard, touchpad
Communications
Wireless
2-cell lithium polymer
32 Wh
Run Time
Up to 11 hours
Battery Run Time
Video playback: up to 11 hours
AC Adapter
Input
Output
10 Watt, 5 V, 2 A
Connections & Expansion
Micro-HDMI , Headphone/microphone combo jack , Micro-USB 2.0 , USB 2.0
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Glacier grey
Case Material
Plastic, metal
Security
Power adapter
UL, C-Tick, BSMI, CB, CCC, FCC, RoHS, A-Tick, GOST-R, CECP, iDA, ErP 2013
SAR Value
580 g
Dimensions (WxDxH) / Weight Details
26.1 cm x 17.5 cm x 2 cm / 1.08 kg - tablet with keyboard , 26.1 cm x 17.5 cm x 0.9 cm / 580 g - tablet , 26.1 cm x 17.5 cm x 1 cm / 500 g - keyboard dock
ENERGY STAR Certified
