For effortless mobility and productivity, Transformer Book T101HA is very compact. Even with the keyboard attached, T101HA is still a very travel-friendly. With a device this compact and light, you'll never have an excuse to leave it at home. Transformer Book T101HA's reversible hinge makes it even more versatile! Detach and flip the tablet, then reattach it for two fantastic modes. Exclusive ASUS Tru2Life Video and TruVivid technologies ensure amazing images in any situation, with sharp, realistic videos and fewer annoying reflections.
Your slim and ultra-light mobile companion
For effortless mobility and productivity, Transformer Book T101HA is very compact. Even with the keyboard attached, T101HA is still a very travel-friendly. With a device this compact and light, you'll never have an excuse to leave it at home. -
Multiple modes with brighter, sharper, clear, viewing experience
Transformer Book T101HA's reversible hinge makes it even more versatile! Detach and flip the tablet, then reattach it for two fantastic modes. Exclusive ASUS Tru2Life Video and TruVivid technologies ensure amazing images in any situation, with sharp, realistic videos and fewer annoying reflections. -
Amazing all-day battery life
When you have a busy mobile lifestyle, great battery life is essential. You can be sure that Transformer Book T101HA will be right there whenever you need it. You can charge T101HA via its micro USB port, so you can use a mobile charger or any power bank with a micro USB connector. With T101HA, traveling is a pleasure, not a chore! -
Every connection you need
Even though Transformer Book T101HA is incredibly slim and light, it has all the ports you need to connect devices on the go, including USB, micro USB, micro HDMI, micro SD and a headphone jack. And even better, all these ports are on the tablet, so they're always available. T101HA is small, but big on connectivity! -
Faster, more reliable Wi-Fi
Transformer Book T101HA features the dual-band 802.11ac Wi-Fi technology for strong, stable signals. It's less prone to interference from other wireless devices, too, so you can stream high-definition movies and videos smoothly without stuttering. -
Maximum comfort, minimum size
Its precision touchpad has palm-rejection technology, and the ergonomic keyboard has 1.5 mm key travel with a tactile bounce force, making it a real pleasure to use. Typing on a compact device has never been this comfortable!
- ASUS Transformer Book T101HA GR029R - 10.1" - Atom x5 Z8350 - 4 GB RAM - 64 GB eMMC
- Product Type
- Tablet - with keyboard dock
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Atom x5 Z8350 / 1.44 GHz (1.92 GHz) / 2 MB Cache
- Memory
- 4 GB DDR3 (provided memory is soldered)
- Storage
- 64 GB - eMMC
- Display
- 10.1" LED backlight touchscreen 1280 x 800 / WXGA
- Graphics
- Intel HD Graphics 400
- Input Device
- Keyboard, touchpad
- Integrated Webcam
- Networking
- 802.11ac, Bluetooth 4.1
- Battery
- 2-cell - up to 11 hours
- Security
- Trusted Platform Module (TPM) Security Chip
- Glacier grey
- Dimensions (WxDxH) - tablet
- 26.1 cm x 17.5 cm x 0.9 cm
- 580 g
- Environmental Standards
- ENERGY STAR Qualified
- SAR
- 0.856 W/kg (body), 0.856 W/kg (limb)
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Max Turbo Speed
- 1.92 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3 SDRAM
Storage
- Main Storage
- 64 GB SSD - (eMMC)
Display
- 10.1"
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Resolution
- 1280 x 800 (WXGA)
- Widescreen
- Image Aspect Ratio
- 16:10
- Image Brightness
- 400 cd/m²
- Ultra Slim Design, ASUS Splendid Video Intelligence Technology, glare, WideView, 60% NTSC colour gamut, ASUS TruVivid technology, Tru2Life
Audio & Video
- Graphics Processor
- Camera
- Resolution
- 2 Megapixel
- Sound
- Stereo speakers, microphone
- Audio Features
- ASUS SonicMaster
Input
Communications
- Wireless
- Technology
- 2-cell lithium polymer
- Capacity
- 32 Wh
- Run Time
- Up to 11 hours
- Battery Run Time
- Video playback: up to 11 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 10 Watt, 5 V, 2 A
Connections & Expansion
- Micro-HDMI , Headphone/microphone combo jack , Micro-USB 2.0 , USB 2.0
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
- Glacier grey
- Case Material
- Plastic, metal
- Security
- Included Accessories
- Power adapter
- UL, C-Tick, BSMI, CB, CCC, FCC, RoHS, A-Tick, GOST-R, CECP, iDA, ErP 2013
- SAR Value
- 580 g
- Dimensions (WxDxH) / Weight Details
- 26.1 cm x 17.5 cm x 2 cm / 1.08 kg - tablet with keyboard , 26.1 cm x 17.5 cm x 0.9 cm / 580 g - tablet , 26.1 cm x 17.5 cm x 1 cm / 500 g - keyboard dock
- ENERGY STAR Certified
