Asus T100HA-FU029T Atom Z8500 4GB 64GB 10.1" Windows 10
Quicklinx: CBN1WS00 Mfr#: T100HA-FU029T
  • IEEE 802.11n
  • Bluetooth 4.0
Let's admit it - carrying both a tablet and a laptop is a nuisance. The T100HA is a 2-in-1, which means exactly what it says - it's a laptop with a keyboard. So it's two devices, in one amazing package. It's a simple idea that's elegant and convenient, too. Need to work? It's a powerful laptop. Time to relax? Detach the keyboard and it's a handy tablet. No fuss, no hassle. What's more, it's the only 2-in-1 with the revolutionary time-saving USB 3.1 Type-C port. And with up to an incredible 12 hours battery life, it's always ready - for work or play.
  • Incredible 2-in-1 and amazing battery life
  • Brilliant design, brilliant colors
    With a lid finished in ultra-cool anodized aluminum, T100HA is not just designed to make a style statement. Yes, it's elegant. And of course it's sophisticated. But it's also durable and practical - and it feels great.
  • Even thinner even lighter
    The original Transformer Book T100 was no heavyweight, the tablet is 20% thinner than before, so you'll never have an excuse to leave it at home. Take it everywhere, store it anywhere.
  • 12 hours of battery power
    The ultimate portable companion deserves the ultimate stamina, and with up to 12 hours battery life you can rest assured it will keep going as long as your mobile lifestyle demands.
  • USB just got smarter
    Sometimes, smaller can be better. The humble USB port is great, but it's definitely a bit clunky, and can be awkward to plug things into. The version of the USB port, called a Type-C port, is much smaller than a standard USB port, but it does just as much and has the extra benefit of being reversible. So there's no more struggling to work out which way up a connector is when you want to plug it in. And you still get the blindingly-fast capabilities of SuperSpeed USB 3.0, so data transfers are quick and speedy - up to 10 times faster than USB 2.0.
ASUS Transformer Book T100HA-FU029T - 10.1" - Intel Atom x5 - Z8500 - 4 GB RAM - 64 GB eMMC
Tablet - with keyboard dock
Operating System
Win 10 Home 64-bit
Intel Atom x5 Z8500 / 1.44 GHz, up to 2.24 GHz / 2 MB Cache
4 GB LPDDR3 (provided memory is soldered)
Storage
64 GB eMMC
Display
10.1" LED backlight touchscreen 1280 x 800 / WXGA
Graphics
Intel HD Graphics
Input Device
Keyboard, touchpad
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0
2-cell - up to 12 hours
Asteroid grey
Dimensions (WxDxH) - tablet
26.5 cm x 17.5 cm x 8.4 mm
500 g
Environmental Standards
ENERGY STAR Qualified
0.462 W/kg (body) , 0.462 W/kg (limb)
Operating System
Windows 10 Home 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
2.24 GHz
Number of Cores
Quad-Core
Cache
2 MB
64-bit Computing
RAM
4 GB (provided memory is soldered)
LPDDR3 SDRAM
Speed
1600 MHz
Storage
Main Storage
64 GB eMMC
Display
10.1"
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1280 x 800 (WXGA)
Widescreen
Image Aspect Ratio
16:10
Image Brightness
350 cd/m²
Colour Gamut
60% NTSC
Detachable, glare, WideView
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Resolution
5 Megapixel (rear), 2 Megapixel (front)
Sound
Stereo speakers, microphone
Input
Keyboard, touchpad
Communications
Wireless
2-cell lithium polymer
30 Wh
Run Time
Up to 12 hours
Battery Run Time
Video playback: up to 12 hours
AC Adapter
Input
Output
10 Watt, 5 V, 2 A
Connections & Expansion
Micro-HDMI , Headphone/microphone combo jack , Micro-USB 2.0 , USB 2.0 , USB-C
Memory Card Reader
2 in 1 (microSD, microSDHC, microSDXC)
Asteroid grey
Case Material
Plastic, metal
Power adapter
UL, BSMI, CB, CCC, MIC, FCC, RoHS, GOST-R, CECP, iDA, ErP 2013
SAR Value
0.462 W/kg (body), 0.462 W/kg (limb)
500 g
Dimensions (WxDxH) / Weight Details
26.5 cm x 17.5 cm x 1.84 cm / 1 kg - tablet with keyboard
Sustainability Information
ENERGY STAR Certified
CBN1 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
