ASUS SV425 digital signage delivers a captivating viewer experience with high-quality digital content displayed at up to 1920 x 1080 Full HD resolutions. The ASUS SV425 uses durable industrial-quality panels designed for all-day use. It has 500nits brightness levels, making them suitable for a wide range of commercial applications. The ASUS SV425 conforms to the Open Pluggable Specification (OPS), ensuring maximum flexibility and optimum interoperability with existing systems.
Capture attention with more vibrant digital signage
ASUS SV425 digital signage delivers a captivating viewer experience with high-quality digital content displayed at up to 1920 x 1080 Full HD resolutions. The ASUS SV425 uses durable industrial-quality panels designed for all-day use. It has 500nits brightness levels, making them suitable for a wide range of commercial applications. The ASUS SV425 conforms to the Open Pluggable Specification (OPS), ensuring maximum flexibility and optimum interoperability with existing systems. -
Open Pluggable Specification (OPS) support for easy installation and maintenance
The SV425 is OPS-compatible, allowing displays to accommodate a compatible plug-in PC module. OPS technology simplifies device installation, content streaming and maintenance, resulting in lower overall costs. An onboard PC simplifies content delivery and management, and also allows defective installations to be repaired by simply replacing the entire pluggable PC module when a hardware fault occurs. -
Industrial-quality panels designed for 24/7 operation
The SV425 display can operate continuously for 24 hours a day, 7 days a week, thanks to the industrial-quality LCD display modules that has much higher durability than consumer-grade panels. This provides greater reliability and uninterrupted content delivery, making them the ideal solution where continuous operation and reliability are demanded. -
Exclusive support for both vertical and horizontal placement
The SV425 allows you to create content in either portrait or landscape mode. The industrial-quality LCD panels in the SV425 has wide 178° horizontal and vertical viewing angles, meaning they can be installed in either portrait or landscape orientation for maximum flexibility without any color shift. -
Extensive connectivity
The SV425 includes a DisplayPort input, which is a high-bandwidth video-plus-audio interface that can transmit the signal over up to 15m cable runs. It delivers higher performance than any other digital interface, providing access to wider range of digital content. HDMI, DVI-D, D-Sub and BNC connectors are also included for comprehensive compatibility with a wide range.
- ASUS SV425 42" LED-backlit LCD display - Full HD - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 42"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), DisplayPort, serial RS-232
- LCD Backlight Technology
- LED backlight
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- Included Accessories
- Remote control, 2 AAA batteries
- Voltage
- AC 120/230 V (50/60 Hz)
- Power Consumption Stand by
- 0.5 Watt
- Dimensions (WxDxH) - without stand
- 96.58 cm x 6.9 cm x 55.88 cm
- 18.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- Diagonal Class
- 42"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- Dimensions
- Without stand
- 96.58 cm
- 6.9 cm
- 55.88 cm
- 18.3 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- LED backlight
- Colour Depth
- 1 billion colours
- Image Contrast Ratio
- 4000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.4845 x 0.4845mm
- Security lock slot (cable lock sold separately), Intel OPS compatible
Stands & Mounts
- Stand
- Included
- Stand Design
- Tabletop
- Flat Panel Mount Interface
- 200 x 200 mm, 400 x 200 mm
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Speakers
- 1 x left channel speaker - 10 Watt , 1 x right channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Connector Type
- VGA input - rear , DVI-D input , DVI-I , HDMI input , DisplayPort input , Audio line-in , Audio input , Audio output , LAN , Serial input , Serial output , Component video input
- 2 AAA batteries
- Cables Included
- VGA cable - 1.8 m
- WEEE
Sustainability Information
- ENERGY STAR Certified
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
- No
Dimensions & Weight Details
- Dimensions & Weight Details
- Panel without stand - 96.58 cm x 6.9 cm x 55.88 cm x 18.3 kg , Panel with stand - 96.58 cm x 40 cm x 60.14 cm x 20.3 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
