ROG Strix H270I Gaming motherboards combine a compact form factor with bold aesthetics, premier performance, and incredible audio to deliver gaming experiences with punch and amazing style.
Double-decker heatsink
ROG Strix H270I Gaming has an innovative double-decker heatsink design that allows the M.2 SSD to be stacked atop of the PCH heat sink, which is then topped off with an additional metal heatsink for the M.2 drive. The two heatsinks are thermally isolated to prevent the PCH and M.2 from affecting each other. -
Outshine the competition
ASUS Aura RGB LED technology makes ROG Strix H270I Gaming the control hub for your illumination ambitions - so it's easy to synchronize incredible lighting effects between compatible components, including RGB LED strips, graphics cards, keyboards and even mice. -
Superior sound
ROG Strix's audio technology is more advanced, delivering an exceptional signal-to-noise ratio on the line-in connection for great recording quality. -
Cooler by design
Play quieter and cooler with advanced fan and water-pump controls for undisturbed gaming. With onboard thermal sensors and hardware-level PWM/DC mode detection, you can be sure that every fan achieves a better balance of high cooling performance and low noise.
- ASUS ROG STRIX H270I GAMING - motherboard - mini ITX - LGA1151 Socket - H270
- Product Type
- Motherboard - mini ITX
- Chipset Type
- Intel H270
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 32 GB
- RAM Supported
- 2 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 4 x SATA-600 (RAID), 2 x M.2
- USB / FireWire Ports
- 6 x USB 3.1 Gen 1 + (2 x USB 3.1 Gen 1 via headers)
- Max Allocated RAM Size
- 1 GB
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
- Product Type
- Chipset Type
- Intel H270
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1 GB
Audio
- Audio Codec
- SupremeFX (S1220A)
- High Definition Audio
LAN
- Network Controller
- Intel I219V / Realtek RTL8111H
- Network Interfaces
- Expansion Slots
- 1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16
- Storage Interfaces
- SATA-600 -connectors: 4 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x M.2
- RAID Features
- Intel Rapid Storage Technology
- 1 x HDMI , 1 x DisplayPort , 2 x LAN (Gigabit Ethernet) , 6 x USB 3.1 Gen 1 , 1 x TOSLINK , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack
- Internal Interfaces
- 2 x USB 3.1 Gen 1 - header , 1 x speaker - header , 1 x audio - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- Multilingual BIOS, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support
- Hardware Features
- Jack retasking, ASUS Q-Design, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, Intel Smart Response Technology, SupremeFX Shielding technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASUS Enhanced DRAM Overcurrent Protection, ASUS Stainless Steel Back I/O, dual headphone amplifiers, LANGuard, GameFirst IV, ASUS Gamer's Guardian, AURA RGB Lighting Control, ASUS SafeSlot, 3D printing friendly, Intel Optane Memory Ready, Sonic Radar III, Sonic Studio III, double-decker heatsink design
- Included Accessories
- Cable ties, cable labels, ASUS 2T2R Wi-Fi moving aerials, I/O back cover, ROG fan stickers, 2 x M.2 screws, RGB (RGBW) LED strip extension cable, M.2 bracket
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS AI Charger, ROG CPU-Z, ASUS AI Suite III, Overwolf, ROG Aura, ROG GameFirst IV, ASUS ROG RAMCache II, ROG CloneDrive
- Plug and Play
- 17 cm
- 17 cm
