Your basket is empty
Asus Strix Glide Speed Gaming Pad / Mouse Mat
Quicklinx: BRQMWS00 Mfr#: 90YH00F1-BDUA00
High-quality Strix Glide mouse pads are designed as the perfect complement for gamers. Choose Strix Glide Control or Strix Glide Speed based on your gaming style and preference.
Smooth and flat surface ensures mouse glides quickly across the entire pad with zero hindrance - just perfect for games that demand fast, efficient movement.
Optimized fabric allows pixel-precise tracking no matter whether you use an optical or laser mouse.
The embroidered edge has undergone intensive testing, providing better feel, comfort and durability.
Taken from the ancient Roman and Greek word for owl, Strix means the keenest hearing and sharpest eyesight. Strix means feeling your environment so that you detect and react to the slightest movement. Strix means survival on the very edge of instinct. Strix is in your blood.
ASUS STRIX GLIDE SPEED - mouse pad
Mouse pad
Product Material
Fabric
40 cm x 30 cm
219 g
Mouse pad
Product Material
Fabric
40 cm
30 cm
Thickness
0.3 cm
219 g
