The ROG Strix B250 motherboards combine bold aesthetics with great performance and incredible audio to deliver amazing gaming experiences and style. Support for advanced processors and technologies, plus exclusive ROG innovations, take performance to another level to give you the edge against opponents.
Aggressive look
The ROG Strix B250 Gaming has arrived with the classic ROG color theme and katana-inspired markings for an aggressive look befitting gamers who rule the battlefield. Above its sleek and stealthy PCB accented with striking, sword-slash patterns stands a ROG nameplate that boldly declares your gaming pride. -
Superior sound
ROG Strix's awesome audio technology has leveled up, delivering an exceptional signal-to-noise ratio on the line-in connection for great ROG recording quality. -
Cooler by design
Play quieter and cooler with advanced fan controls for undisturbed gaming. With onboard thermal sensors and hardware-level PWM/DC mode detection, you can be sure that every fan achieves better balance of high-cooling performance and low noise - so you enjoy all the performance you demand with none of the racket. -
VR ready
The ROG Strix B250 Gaming isn't just VR ready - it goes way beyond. It has been tested with loads of advanced components to ensure that your productivity, gaming and entertainment needs are tuned for maximum performance after you've taken off the headset.
- ASUS ROG STRIX B250G GAMING - motherboard - micro ATX - LGA1151 Socket - B250
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel B250
- Processor Socket
- 1 x LGA1151 Socket
- Compatible Processors
- Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
- Max RAM Size
- 64 GB
- RAM Supported
- 4 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600, 2 x M.2
- USB / FireWire Ports
- 2 x USB 3.0 + 4 x USB 2.0 + (4 x USB 3.0 + 2 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1 GB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Product Type
- Chipset Type
- Intel B250
- Processor Socket
- LGA1151 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 64 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1 GB
Audio
- Audio Codec
- SupremeFX (S1220A)
- High Definition Audio
LAN
- Network Controller
- Intel I219V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 3.0 x1
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA , SATA-600 / PCIe 3.0 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x M.2
- 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 4 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x DVI
- Internal Interfaces
- 2 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x serial - header
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS MyLogo, UEFI BIOS, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support, ACPI 6.1 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, ASUS Q-Design, ESD Guards, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, SupremeFX Shielding technology, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, ASUS Fan Xpert 3, ASUS Gamer's Guardian, ASUS SafeSlot, 3D printing friendly
- Included Accessories
- Cable labels, 1 x M.2 screw, I/O back cover, ROG fan stickers
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS AI Charger, ROG CPU-Z, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Overwolf, ASUS EZ Flash 3
- Plug and Play
- 24.4 cm
- 21.8 cm
