Asus STRIX B250F GAMING Intel B250 S1151 DDR4 M.2 USB3.1 ATX
Quicklinx: CLYFWS00 Mfr#: STRIX B250F GAMING
  • FanXpert 4 allows for dynamic fan calibration and optimized system cooling while gaming.
  • Unmatched personalization with ASUS exclusive AURA Sync RGB lighting, an additional RGB header and a 3D-printing friendly mount.
  • Maximize your connectivity and speed with Dual M.2, front panel USB 3.1 and IntelĀ® Optaneā„¢ Memory compatibility.
  • Patent-pending SafeSlot features an injection moulding process that integrates metal framing for a stronger, firmly anchored PCIe slot built for heavyweight GPUs.
  • Industry-leading 8-channel HD audio with the ROG exclusive SupremeFX S1220A driven by Japanese capacitors.
  • Aura lighting control
    Create your own custom LED lighting effects with the intuitive Aura software. Cast a stunning multi-color glow across your build with the powerful RGB LEDs built in to ROG Strix B250F Gaming, or attach separate RGB strips using the two onboard 4-pin headers. You can even use both at the same time and enjoy perfect lighting synchronization. Fire up Aura and enjoy the creative freedom of nine different lighting themes.
  • Outshine the competition
    SUS Aura Sync RGB LED technology makes ROG Strix B250FGaming the control hub for your illumination ambitions - so it's easy to synchronize incredible lighting effects between compatible components, including RGB LED strips, graphics cards, keyboards and even mice! Change all LEDs in unison or employ dynamic modes to flow the illumination effects smoothly across all synchronized devices.
  • Exclusive 3D mount for easy installation
    Dedicated 3D mounts on the motherboard makes fitting 3D-printed parts easy. Using the same screws as M.2 drives and standard motherboard mounting holes, you can easily add nameplates, cable covers, or an M.2 fan holder.
  • Shielded audio, superior sound
    ROG Strix's awesome SupremeFX audio technology has leveled up, delivering an exceptional 113 dB signal-to-noise ratio on the line-in connection for best-ever ROG recording quality.
  • Sonic Studio III
    ROG Strix's Sonic Studio III audio-effects station has an intelligent routing feature made for streaming. The routing feature ports streams to different outputs giving you full control over who hears what. With Sonic Studio III, you now can share your exciting in-game moments without worrying about frivolous DCMA takedown requests. In addition to that, Sonic Studio III also comes with app-level preferences for instant audio profiles, and improved noise filtering for conversations with total clarity.
  • Cooler by design
    Play quieter and cooler with advanced fan and water-pump controls for the ultimate in undisturbed gaming. With onboard thermal sensors and hardware-level 4-pin/3-pin PWM/DC mode detection, Fan Xpert 4 makes sure every fan achieves the best balance of high cooling performance and low noise, so you enjoy all the performance you demand with none of the racket.
ASUS ROG STRIX B250F GAMING - motherboard - ATX - LGA1151 Socket - B250
Motherboard - ATX
Chipset Type
Intel B250
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600, 2 x M.2
USB / FireWire Ports
1 x USB-C + 1 x USB 3.1 + 2 x USB 3.0 + 4 x USB 2.0 + (4 x USB 3.0 + 2 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Motherboard - ATX
Chipset Type
Intel B250
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1 GB
Audio
Audio Codec
SupremeFX (S1220A)
High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 3.0 x16 (x4 mode) , 4 x PCIe 3.0 x1
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA , SATA-600 -connectors: 1 x M.2 , PCIe 3.0 -connectors: 1 x M.2
1 x HDMI , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x USB 3.1 , 1 x USB-C , 2 x USB 3.0 , 4 x USB 2.0 , 1 x PS/2 keyboard / mouse , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x DVI-D , 1 x TOSLINK
Internal Interfaces
2 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x serial - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, UEFI BIOS, ASUS EZ Flash 3, DMI 3.0 support, SMBIOS 3.0 support, ACPI 6.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, ASUS Q-Design, ESD Guards, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Intel Clear Video HD Technology, SupremeFX Shielding technology, AMD CrossFireX technology support, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, dual headphone amplifiers, LANGuard, ASUS Gamer's Guardian, AURA RGB Lighting Control, ASUS Fan Xpert 4, ASUS SafeSlot, 3D printing friendly, Sonic Radar III, Sonic Studio III
Cable labels, 1 x M.2 screw, I/O back cover, ROG fan stickers, RGB (RGBW) LED strip extension cable, 3D printing mount package
4 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS AI Charger, ROG CPU-Z, ASUS AI Suite III, Overwolf, ROG Aura, ROG GameFirst IV, ASUS ROG RAMCache II, ROG CloneDrive
Plug and Play
30.5 cm
24.4 cm
