Asus SP6540-T 64.5" 1920x1080 Display Port DVI HDMI Interactive
Quicklinx: C06DWS00 Mfr#: SP6540-T
  • 1080p
  • USB
The ASUS SP6540-T Interactive Whiteboard Touch Display utilizes the latest touch solutions and supports fingertip and stylus input to give you more engaging levels of interactivity. The SP6540-T features a Full HD 1920 x 1080p display with wide 178-degree viewing angles. Four-point touch capabilities let you get creative with friends and colleagues, allowing you to share ideas or mark notes onscreen on the spot. With a max brightness of 350 nits, it is bright enough to be used in meeting rooms, so there's no need to dim the lights. Whether you're engaging a small group or a larger audience, the SP6540-T helps you get your message across in new and innovative ways. It is suited for a myriad of uses, and is ideal for use in classrooms, boardrooms, or in TV studios.
The SP6540-T easily connects to a PC or laptop thanks to extensive connectivity options like DisplayPort, HDMI, DVI-D, and D-Sub. The USB port provides a 5V DC to power a Miracast dongle so you can easily stream documents, presentations, and other files stored in your mobile device.
The LED-backlit panel used in the SP6540-T is 20 to 50% more energy efficient than conventional CCFL backlight displays. It is mounted on a scratch-resistant metal chassis to give you commercial-grade durability and reliability. It is VESA mount-compatible as well, and can be easily hung on any wall.
  • Touch makes communication better
  • Extensive connectivity options and wireless capabilities
  • Energy-efficient LED-backlit panel on a robust metal chassis
  • Powerful built-in 10 W speakers
    The SP6540-T features built-in 10 W speakers to give you a complete audiovisual experience. The speakers' rear placement maintains the display's streamlined profile, and gets rid of the need for external speakers.
ASUS SP6540-T 65" LED-backlit LCD display - Full HD - for interactive communication
LED-backlit LCD flat panel display with whiteboard and touchscreen
Diagonal Class
65"
Commercial Use
Yes - interactive
Resolution
1920 x 1080
Display Format
1080p
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
DVI, VGA (HD-15), HDMI, DisplayPort, USB, serial RS-232
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, remote control
220 Watt
Power Consumption Stand by
0.5 Watt
150.7 cm x 9.6 cm x 88.2 cm
40 kg
220 Watt
Diagonal Class
65"
Commercial Use
Yes - interactive
Combined With
Whiteboard and touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
1 ports
PC Interface
Protection
Protection glass
150.7 cm
9.6 cm
88.2 cm
40 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Image Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
4
Response Time
8 ms
Stands & Mounts
Flat Panel Mount Interface
100 x 100 mm, 400 x 400 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
1 x left channel speaker - 10 Watt , 1 x right channel speaker - 10 Watt
Connector Type
VGA input , HDMI input , DisplayPort input , Audio input , Audio output , DVI-D input , Serial input , Serial output , USB 2.0 , USB 2.0
Remote control
BSMI, CCC, CEL
Power supply
0.5 Watt
On / Off Switch
