ASUS SE655-Y Commercial Media Player Displays feature 178-degree wide-view angle Full HD 1920 x 1080 panels for stunning visuals. With 450 cd/m2 brightness, making SE655-Y ideal for semi-outdoor wall-mounted, shelved, or end-cap installations. An embedded ambient light sensor automatically adjusts display brightness depending on environmental conditions. SE655-Y display has a built-in multimedia player that supports various video, audio, and image files, as well as Windows Office and PDF documents. It comes with 4 GB of onboard memory, enough storage for most media files. The all-in-one design of the SE655-Y makes it an ideal, cost-effective solution for any business. You can put it at a shop entrance, display window, or exhibition booth to entice customers with product and sales promotions. The embedded media player makes it easy for you to conduct boardroom presentations; there are also extensive connectivity options like DisplayPort, HDMI, DVI-D, and D-Sub for laptop users.
Giving you the best images in any environment
The SE655-Y will capture viewers' attention with high quality digital content at Full HD 1920 x 1080 resolution. There's little or no color shift, image distortion or degradation too, thanks to the use of 178° wide-view angle panels. An ambient light sensor intelligently adjusts display brightness depending on environmental conditions to deliver the best images anytime, anywhere. -
Plug-and-Play convenience and support for numerous file formats
SE655-Y displays support a wide range of file formats and can automatically detect and play them the moment you plug in a USB drive. It's especially useful in the boardroom, allowing you to easily share your Microsoft Office and PDF files. It also comes with extensive connectivity options like DisplayPort, HDMI, DVI-D, and D-Sub for laptop users. For added convenience, these displays come with a built-in media player, stereo speakers, and 4GB of storage space. Its all-in-one designs make them ideal cost-effective solutions for any business. SE655-Y displays are suited for use in semi-outdoor environments such as train stations as well, where they can serve as information points for commuters. -
Power built-in 10 W speakers
Select SE655-Y models feature built-in twin 10 W speakers to provide quality audio to accompany what's onscreen. The speakers' rear placement maintains the display's streamlined profile, and gets rid of the need for external speakers.
- ASUS SE655-Y 65" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 65"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), HDMI, DisplayPort, USB, serial RS-232
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Digital signage
- Speaker System
- 2 speakers
- DVR
- Flash - 4 GB
- Storage Drive Capacity
- 4 GB
- Storage Capacity
- 4 GB
- USB
- Included Accessories
- Remote control, IR extension cord
- Voltage
- AC 120/230 V (50/60 Hz)
- 300 Watt
- Power Consumption Stand by
- 0.5 Watt
- 152.2 cm x 8.2 cm x 88.3 cm
- 51 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 300 Watt
- Diagonal Class
- 65"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- Modes
- Portrait mode, landscape mode
- 152.2 cm
- 8.2 cm
- 88.3 cm
- 51 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 4000:1
- Dynamic Contrast Ratio
- 45000:1
- Brightness
- 450 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.744 x 0.744mm
- Response Time
- 8 ms
- Digital signage
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
DVR
- DVR
- Flash - 4 GB
Media Player
- Supported Video Formats
- MPEG-4, Xvid, AVI, MOV, VOB, RMVB, MPG
- Supported Audio Formats
- MP3, WAV, AC3, AAC, Ogg Vorbis
- Supported Pictures Formats
- BMP, JPG
- USB Port
- USB Ports Qty
- 1
- Configuration
- 4 GB
- 4 GB
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Connector Type
- VGA input , VGA output , Component video input , HDMI input , DisplayPort input , Audio input , Audio output , Audio output , DVI-D input , Serial input , Serial output , USB 2.0 , LAN , USB 2.0 , Remote control
- IR extension cord
- Cables Included
- VGA cable
- Plug and Play, UL, VCCI, BSMI, CB, FCC, PSE Mark, RCM
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
- 0 °C
- 40 °C
- 20 - 80%
