Asus SE555-Y 54.5" 1920x1080 Display Port DVI HDMI LFD
Quicklinx: C06BWS00 Mfr#: SE555-Y
  • 1080p
  • USB
ASUS SE555-Y Commercial Media Player Displays feature 178-degree wide-view angle Full HD panels for stunning visuals. With a great brightness, making SE555-Y ideal for semi-outdoor wall-mounted, shelved, or end-cap installations. An embedded ambient light sensor automatically adjusts display brightness depending on environmental conditions.
SE555-Y display has a built-in multimedia player that supports various video, audio, and image files. The all-in-one design of the SE555-Y makes it an ideal, cost-effective solution for any business. You can put it at a shop entrance, display window, or exhibition booth to entice customers with product and sales promotions. The embedded media player makes it easy for you to conduct boardroom presentations; there are also extensive connectivity possibilities like DisplayPort, HDMI, DVI-D, and D-Sub for laptop users.
  • Giving you the optimal images in any environment
    The SE555-Y will capture viewers' attention with high quality digital content at Full HD resolution. There's little or no color shift, image distortion or degradation too, thanks to the use of 178° wide-view angle panels. An ambient light sensor intelligently adjusts display brightness depending on environmental conditions to deliver great images anytime, anywhere.
  • Plug and Play convenience and support for numerous file formats
    SE555-Y displays support a wide range of file formats and can automatically detect and play them the moment you plug in a USB drive. It's especially useful in the boardroom. Its all-in-one designs make them ideal cost-effective solutions for any business. SE555-Y displays are suited for use in semi-outdoor environments such as train stations as well, where they can serve as information points for commuters.
  • Industrial-grade panel with metal chassis
    SE555-Y displays feature industrial-grade panels designed for round-the-clock operation for reliable and uninterrupted use. The LED panels consume less energy. Scratch-resistant metal chassis give you commercial-grade durability and reliability.
ASUS SE555-Y 55" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
55"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15), HDMI, DisplayPort, USB, serial RS-232
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Digital signage
Speaker System
2 speakers
DVR
Flash - 4 GB
Storage Drive Capacity
4 GB
Storage Capacity
4 GB
USB
Remote control, IR extension cord
Voltage
200 Watt
Power Consumption Stand by
0.5 Watt
124 cm x 5 cm x 71 cm
28.5 kg
Environmental Standards
ENERGY STAR Qualified
200 Watt
Diagonal Class
55"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
Modes
Portrait mode, landscape mode
124 cm
5 cm
71 cm
28.5 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
50000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.21 x 0.63mm
Response Time
6.5 ms
Commercial Features
Digital signage
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
DVR
DVR
Flash - 4 GB
Media Player
Supported Video Formats
MPEG-4, Xvid, AVI, MOV, VOB, RMVB, MPG
Supported Audio Formats
MP3, WAV, AC3, AAC, Ogg Vorbis
Supported Pictures Formats
BMP, JPG
USB Port
USB Ports Qty
1
Configuration
4 GB
4 GB
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
VGA input , VGA output , Component video input , HDMI input , DisplayPort input , Audio input , Audio output , Audio output , DVI-D input , Serial input , Serial output , USB 2.0 , LAN , USB 2.0 , Remote control
IR extension cord
VGA cable
Plug and Play, UL, VCCI, BSMI, CB, FCC, PSE Mark, RCM
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
On / Off Switch
20 - 80%
