Asus SE465-Y 46" 1920x1080 Display Port DVI HDMI LFD
Quicklinx: C06CWS00 Mfr#: SE465-Y
  • 1080p
  • USB
ASUS SE465-Y Commercial Media Player displays feature 178-degree wide-view angle Full HD 1920 x 1080 panels for stunning visuals. With 500 cd/m2 brightness, making SE465-Y ideal for semi-outdoor wall-mounted, shelved, or end-cap installations. An embedded ambient light sensor automatically adjusts display brightness depending on environmental conditions.
SE465-Y display has a built-in multimedia player that supports various video, audio, and image files, as well as Windows Office and PDF documents. It comes with 4GB of onboard memory, enough storage for most media files.
The all-in-one design of the SE465-Y makes it an ideal, cost-effective solution for any business. You can put it at a shop entrance, display window, or exhibition booth to entice customers with product and sales promotions. The embedded media player makes it easy for you to conduct boardroom presentations; there are also extensive connectivity options like DisplayPort, HDMI, DVI-D, and D-Sub for laptop users.
  • Giving you the best images in any environment
    The SE465-Y will capture viewers' attention with high quality digital content at Full HD 1920 x 1080 resolution. There's little or no color shift, image distortion or degradation too, thanks to the use of 178° wide-view angle panels. An ambient light sensor intelligently adjusts display brightness depending on environmental conditions to deliver the best images anytime, anywhere.
  • Plug-and-Play convenience and support for numerous file formats
    SE465-Y displays support a wide range of file formats and can automatically detect and play them the moment you plug in a USB drive. It's especially useful in the boardroom, allowing you to easily share your Microsoft Office and PDF files. It also comes with extensive connectivity options like DisplayPort, HDMI, DVI-D, and D-Sub for laptop users. For added convenience, these displays come with a built-in media player, stereo speakers, and 4GB of storage space. Its all-in-one designs make them ideal cost-effective solutions for any business. SE465-Y displays are suited for use in semi-outdoor environments such as train stations as well, where they can serve as information points for commuters.
  • Power built-in 10 W speakers
    Select SE465-Y models feature built-in twin 10 W speakers to provide quality audio to accompany what's onscreen. The speakers' rear placement maintains the display's streamlined profile, and gets rid of the need for external speakers.
ASUS SE465-Y 46" LED-backlit LCD display - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
46"
Commercial Use
Yes - digital signage
Resolution
1920 x 1080
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
LAN
PC Interface
DVI, VGA (HD-15), HDMI, DisplayPort, USB, serial RS-232
LCD Backlight Technology
Edge-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Digital signage
Speaker System
2 speakers
DVR
Flash - 4 GB
Storage Drive Capacity
4 GB
Storage Capacity
4 GB
USB
Remote control, IR extension cord
Voltage
200 Watt
Power Consumption Stand by
0.5 Watt
104.8 cm x 5 cm x 60.2 cm
21.5 kg
Environmental Standards
ENERGY STAR Qualified
200 Watt
Diagonal Class
46"
Commercial Use
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Component, HDMI
HDMI Ports Qty
1 ports
PC Interface
Modes
Portrait mode, landscape mode
104.8 cm
5 cm
60.2 cm
21.5 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Image Aspect Ratio
16:9
Edge-lit LED
Colour Depth
Up to 1.07 billion colours
Image Contrast Ratio
4000:1
Dynamic Contrast Ratio
32000:1
Brightness
500 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Pixel Pitch
0.53025 x 0.53025mm
Response Time
6.5 ms
Commercial Features
Digital signage
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
DVR
DVR
Flash - 4 GB
Media Player
Supported Video Formats
MPEG-4, Xvid, AVI, MOV, VOB, RMVB, MPG
Supported Audio Formats
MP3, WAV, AC3, AAC, Ogg Vorbis
Supported Pictures Formats
BMP, JPG
USB Port
USB Ports Qty
1
Configuration
4 GB
4 GB
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Network & Internet Multimedia
LAN
LAN Protocol
Ethernet
Connector Type
VGA input , VGA output , Component video input , HDMI input , DisplayPort input , Audio input , Audio output , Audio output , DVI-D input , Serial input , Serial output , USB 2.0 , LAN , USB 2.0 , Remote control
IR extension cord
VGA cable
Plug and Play, UL, VCCI, BSMI, CB, FCC, PSE Mark, RCM
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
Power supply
Input Voltage
0.5 Watt
On / Off Switch
20 - 80%
